查看: 653|回复: 0
[日积月累]:颜色总结--需要使用颜色的地方可以做参考
发表于 2005-3-22 20:43:27 | 显示全部楼层 |阅读模式
编写:henryhyg
颜色总结:
方法一.调用MFC系统的颜色对话框
首先:做一个BUTTON用于触发改对话框
//DialogBCZD是BUTTON所在的对话框类
//变量说明
//        CPalette *m_pPalette;
//        COLORREF m_color;
void DialogBCZD::OnButtonColor()
        PLOGPALETTE lp;
        HANDLE hPal;
        hPal = GlobalAlloc(GMEM_MOVEABLE,sizeof(LOGPALETTE)+256*sizeof(PALETTEENTRY));
        lp = (LPLOGPALETTE)GlobalLock(hPal);
        lp->palVersion = 0x300;
        lp->palNumEntries = 256;
        int ii;
        for(ii = 0; ii < 256; ii++)
                lp->palPalEntry[ii].peBlue = 0;
                lp->palPalEntry[ii].peFlags = 0;
                lp->palPalEntry[ii].peGreen = 0;
                lp->palPalEntry[ii].peRed = 0;
        //创建85种红绿蓝颜色
        for(ii=0;ii<85;ii++)
                lp->palPalEntry[ii].peRed = (BYTE)ii*3;
                lp->palPalEntry[ii+86].peBlue = (BYTE)ii*3;
                lp->palPalEntry[ii+86].peFlags = 0;
                lp->palPalEntry[ii+171].peGreen = (BYTE)ii*3;
                lp->palPalEntry[ii+171].peFlags = 0;
        m_pPalette = new CPalette;
        m_pPalette->CreatePalette(lp);
        GlobalUnlock(hPal);
        GlobalFree(hPal);
        delete m_pPalette;        //释放内存
        OnColor();
void DialogBCZD::OnColor()
        int m_nFlag = 1;
        CColorDialog m_Dlg(0,0,NULL);
        if(m_Dlg.DoModal() == IDOK)
                m_color = m_Dlg.GetColor();
                OnView();
void DialogBCZD::OnPalette()
        m_nFlag = 0;
        m_color = RGB(m_nRed,m_nGreen,m_nBlue);
        OnView();
void DialogBCZD::OnView()
        this->UpdateData(true);
        CClientDC dc(this);
        CRgn rgn;
        CRect rect(CPoint(475,410),CSize(50,48));
        rgn.CreateRectRgnIndirect(&rect);
        CBrush brush;
        brush.CreateSolidBrush(m_color);
        dc.FillRgn(&rgn,&brush);
        rgn.DeleteObject();
        brush.DeleteObject();
//这些就可以实现和微软的颜色选择框(调色版)的功能.
PS:具体的头文件可以查MSDN
方法二:调用CAD自身的调色版.
        int color = 0;
        if(Adesk::kTrue == acedSetColorDialog(color,Adesk::kTrue,8))
                acutPrintf("The choose color is :%d",color);
        CAcUiColorComboBox *cb = new CAcUiColorComboBox();
        m_color = cb->GetColorFromIndex(color);
        acutPrintf("The color index is :%d",color);
        OnView();
        UpdateData(false);
说明一下:主要使用CAcUiColorComboBox 类的GetColorFromIndex()方法来获得其索引颜色值,autocad定义这个值在0~255.
PS:virtual COLORREF GetColorFromIndex(int colorIndex);可以获得你要的颜色.就像方法一中的 COLORREF m_color;
在对颜色转化做一下说明
由颜色值得到RGB值
void GetRGBValue(int *R,int *G,int *B)
        *R = GetRValue((DWORD)m_Color);
        *G = GetGValue((DWORD)m_Color);
        *B = GetBValue((DWORD)m_Color);
变量说明:COLORREF m_color;
PS:R,G,B值就是你要的RGB值
RGB得到颜色就不要说了吧:)
COLORREF m_color = RGB(int R,int G,int B);
GMT+8, 2026-11-6 07:13 , Processed in 0.382022 second(s), 32 queries , Gzip On.
