查看: 859|回复: 3
[编程申请]:哪位有批量建立图层的LISP源程序?
发表于 2005-3-24 11:43:54 | 显示全部楼层 |阅读模式
在专业图纸中一般需建立大量图层以提高绘图效率,也给其他专业带来方便,
但建立许多图层本身也是繁琐的工作,通常各专业的图层比较确定和稳定,
要是能有这样的工具,岂不是好事?
哪位有心人有吗?
发表于 2005-3-25 21:05:22 | 显示全部楼层
;    |             CAD图层初始化软件              |
;    |         版本: V0.1   作者: wxh5330        |
;  cs.lsp
;  对CAD绘图的环境进行初始化,建立必要的图层及字体
;  2004/09/21
(defun c:cs ( / orig_blip orig_cmd orig_osnap orig_layer); 指定函式名称
    (setq orig_blip (getvar "blipmode")); 获取系统变数的初始值
    (setq orig_cmd (getvar "cmdecho"))
    (setq orig_osnap (getvar "osmode"))
    (setq orig_layer (getvar "clayer"))
    (setvar "blipmode" 0); 设置系统变数
    (setvar "cmdecho" 0)
    (setvar "osmode" 0)
  (command "layer" "m" "DOTE" "c" "1" "" "lt" "CENTER" "" "");            轴线
  (command "layer" "m" "AXIS" "c" "7" "" "lt" "CONTINUOUS" "" "");        轴圈及一、二道
尺寸线
  (command "layer" "m" "DIM" "c" "7" "" "lt" "CONTINUOUS" "" "");         第三道尺寸、内
部尺寸
  (command "layer" "m" "BEAM" "c" "4" "" "lt" "DASH" "" "");              梁线
  (command "layer" "m" "BEAM-CON" "c" "4" "" "lt" "CONTINUOUS" "" "");    实线梁层
  (command "layer" "m" "BEAM-TXT" "c" "2" "" "lt" "CONTINUOUS" "" "");    梁标注
  (command "layer" "m" "REIN" "c" "1" "" "lt" "CONTINUOUS" "" "");        板钢筋
  (command "layer" "m" "REIN-TXT" "c" "2" "" "lt" "CONTINUOUS" "" "");    板钢筋标注
  (command "layer" "m" "COLUMN" "c" "2" "" "lt" "CONTINUOUS" "" "");      柱、剪力墙
  (command "layer" "m" "COL-NUM" "c" "2" "" "lt" "CONTINUOUS" "" "");     柱、剪力墙编号
  (command "layer" "m" "GZ" "c" "3" "" "lt" "CONTINUOUS" "" "");          构造柱层
  (command "layer" "m" "GZ-NUM" "c" "2" "" "lt" "CONTINUOUS" "" "");      构造柱编号
  (command "layer" "m" "DASH" "c" "7" "" "lt" "DASH" "" "");              虚线层
  (command "layer" "m" "HOLE" "c" "3" "" "lt" "CONTINUOUS" "" "");        厨卫预留洞口管
井
  (command "layer" "m" "CHANGE" "c" "6" "" "lt" "CONTINUOUS" "" "");      修改
  (command "layer" "m" "HATCH" "c" "8" "" "lt" "CONTINUOUS" "" "");       竖向构件填充
  (command "layer" "m" "HATCH2" "c" "9" "" "lt" "CONTINUOUS" "" "");      其他填充
  (command "layer" "m" "MV" "c" "6" "" "lt" "CONTINUOUS" "" "");          动态视图
  (command "layer" "m" "ROOF" "c" "140" "" "lt" "CONTINUOUS" "" "");      屋面轮郭、分水
线
  (command "layer" "m" "EDGE" "c" "100" "" "lt" "CONTINUOUS" "" "");      轮廓线及降板边
缘线
  (command "layer" "m" "FRAME" "c" "7" "" "lt" "CONTINUOUS" "" "");       图框及目录层
  (command "layer" "m" "NODE" "c" "7" "" "lt" "CONTINUOUS" "" "");        节点索引线及引
出线
  (command "layer" "m" "NODE-TXT" "c" "2" "" "lt" "CONTINUOUS" "" "");    节点索引文字说
明
  (command "layer" "m" "PUB-DIM" "c" "7" "" "lt" "CONTINUOUS" "" "");     标高符号
  (command "layer" "m" "PUB-TXT" "c" "2" "" "lt" "CONTINUOUS" "" "");     标高数值
  (command "layer" "m" "BASE" "c" "3" "" "lt" "CONTINUOUS" "" "");        基础、承台
  (command "layer" "m" "PILE" "c" "2" "" "lt" "CONTINUOUS" "" "");        桩
  (command "style" "TSSD" "tssdeng,tssdchn" "0" "0.8" "0" "" "" "");        建立 TSSD 字
体
    (setvar "blipmode" orig_blip); 还原系统变数的设定值
    (setvar "cmdecho" orig_cmd)
    (setvar "osmode" orig_osnap)
    (setvar "clayer" orig_layer)
    (command "osnap" "end,mid,cen,qua,int,per"); 打开端点,中点,中心,象限点,交点及垂点捕
捉
    (command "chamfera" "0"); 将chamfer命令的第一点D值设为0
    (command "chamferb" "0"); 将chamfer命令的第二点D值设为0
    (command "filletrad" "0"); 将fillet命令的半径R值设为0
    (prin1)
); cs.lsp命令结束
    (setq msg_ "\n***** 图层及字体初始化 ***** 指令: cs *****\n")
    (prompt msg_)
    (prin1)
发表于 2005-4-1 23:04:50 | 显示全部楼层
的确比较好用,不过我把图层名称改为中文的就不能用了,不知道是什么回事
发表于 2005-4-2 21:28:43 | 显示全部楼层
试试签名栏下的“专业图层设置”程序。
GMT+8, 2026-11-6 04:10 , Processed in 0.470135 second(s), 38 queries , Gzip On.
