楼主: xiao_longxin
[求助] [求助]:已知一条闭合多义线如何求在其区域内的一点的坐标
 楼主| 发表于 2005-3-31 08:56:44 | 显示全部楼层
最初由 狂刀 发布
[B]现在没空哦。
上面的几位朋友按我的思路可以试写出来的。 [/B]
那请楼主再把思路说详细点
发表于 2005-3-31 19:26:15 | 显示全部楼层
(defun hy_ijlist(lst i j);;;取得列表從i開始以后j數量的片段表如果j為nil則取出i以后的列表從0開始
  (setq aplist '())
  (if (= j nil)
      (repeat (+ i 1)
      (setq lst (cdr lst))
      (setq aplist lst))
      (progn
      (repeat j
      (setq aplist (cons (nth i lst) aplist))
        (setq i (1+ i))
      (setq aplist (reverse aplist))
  aplist
(defun hy_ocom(totlist num / needlist shuldlist numer stay);;處理數據列表分組每一組為NUM個,余項也為組
                                                           ;;FOR EXCAMPLE: (hy_ocom '(-64.4309 100.541 0.0 -106.992 144.345 0.0 1 2) 3)
                                                           ;;return : ((-106.992 144.345 0.0) (-64.4309 100.541 0.0) (1 2))
  (setq needlist totlist)
  (setq shuldlist nil)
  (if (> (length totlist) num)
    (progn
    (setq stay (rem (length totlist) num))
    (setq numer (/ (- (length totlist) stay) num))
    (repeat numer
      (setq shuldlist (cons (hy_ijlist needlist 0 num) shuldlist))
      (setq needlist (hy_ijlist needlist (- num 1) nil))
    (setq shuldlist (reverse shuldlist))
    (if (/= stay 0) (setq remlist (reverse(hy_ijlist (reverse totlist) 0 stay))
                          shuldlist (append shuldlist (list remlist))))
    shuldlist
    nil)
(defun hy_interpoint(object1 object2 / jdtb);;返回兩圖元交點
(vl-load-com)
(setq jdtb (vla-intersectwith (vlax-ename->vla-object object1) (vlax-ename->vla-object object2) acExtendnone))
(setq jdtb (vlax-safearray->list (vlax-variant-value jdtb)))
(hy_ocom jdtb 3)
(defun hy_polyinp(poly / poly1 p1 p2 anglep1 anglep2 line dist1 needpoint
                         pointlist basedis nedis shpoint yourpoint)
  (setvar "osmode" 0)
  (setq poly1 (vlax-ename->vla-object poly))
  (vla-getboundingbox poly1 'p1 'p2)
  (setq p1 (vlax-safearray->list p1)
        p2 (vlax-safearray->list p2)
        anglep1 (angle p1 p2)
        anglep2 (angle p2 p1)
        p1 (polar p1 anglep2 5)
        p2 (polar p2 anglep1 5))
  (command "undo" "be")
  (command "line" p1 p2 "")(setq line (entlast))
  (command "trim" poly "" (list line p1) "")
  (setq dist1 (vla-get-length (vlax-ename->vla-object line)))
  (setq needpoint (polar p2 anglep2 dist1))
  (foreach item (hy_interpoint line poly)
    (if (equal needpoint item 0.00001)
      (setq pointlist(vl-remove item (hy_interpoint line poly)))
  (setq basedis (distance needpoint (nth 0 pointlist)))
  (foreach item pointlist
    (if (<= (setq nedis (distance needpoint item)) basedis)
        (progn (setq basedis nedis)
               (setq shpoint item))
  (setq yourpoint (list (/ (+ (car needpoint) (car shpoint)) 2)
                        (/ (+ (cadr needpoint) (cadr shpoint)) 2)
                        0)
  (vla-delete (vlax-ename->vla-object line))
  (command "undo" "e")
  yourpoint
窃以为这样会比较方便一些,速度较快而且取得的点空间
较大!
发表于 2005-4-1 02:05:18 | 显示全部楼层
老虎不发威还以为是病猫
[iframe h=600 w=600]http://www.xdcad.net/forum/showthread.php?s=&postid=1769053#post1769053[/iframe]
发表于 2006-4-26 20:06:09 | 显示全部楼层
这样的帖子居然没人顶,怎么着也该弄个精华吧.
        感觉狂刀的思路是对的,所有曲线都适用.如果射线法不用做辅助线应该是最通用的,估计AUTOCAD内部机制就是这样,现在用LISP有点不大对劲.OFFSET最简单,同射线法一样,还是不正宗,而且有漏洞.
研究了狂刀兄的程序,an应该是法线的方向角吧,但仍然没弄明白的是怎么判断法线方向是向曲线内还是向曲线外,另外自相交曲线比如8字形还有问题.请狂刀兄赐教.
 楼主| 发表于 2006-4-26 23:17:49 | 显示全部楼层
发表于 2006-4-27 09:11:14 | 显示全部楼层
楼上的函数仅适用于PLINE.对于SPLINE不行.
发表于 2009-5-21 20:50:52 | 显示全部楼层
我实现的思路是这样的:
将闭合曲线和要判断的点位,均辅助生成实体(点可画很小的圆,再生成实体),然后对两实体进行交集判断,当交集为真,则点在闭合曲线内,当交集为假则不在闭合曲线内。
发表于 2009-5-21 21:08:15 | 显示全部楼层
怎么求切线和法线啊.
GMT+8, 2026-11-7 09:42 , Processed in 0.574770 second(s), 40 queries , Gzip On.
