查看: 1913|回复: 6
[LISP程序]:如何在vlisp中重新设置hatch 的pattern, 如solid?
发表于 2003-2-23 06:25:10 | 显示全部楼层 |阅读模式
已领礼包: 145个
发表于 2003-2-23 06:42:42 | 显示全部楼层
Re: [LISP程序]:如何在vlisp中重新设置hatch 的pattern, 如solid?
最初由 lsjjm 发布
[B]如何在vlisp中重新设置hatch 的pattern, 如solid? [/B]
你可以修改实体数据的组码2到需要的样式(修改前,要判断指定的样式必须存在)
  1. <normalfont>
  2. (setq e (car (entsel))
  3. (setq ed (entget e))
  4. (setq new (cons 2 "solid"))
  5. (setq old (assoc 2 ed))
  6. (setq ed (subst new old ed))
  7. (entmod ed)
  8. </normalfont>
同样功能的XDRX_API使用方法:
  1. <normalfont>
  2. (setq e (car (entsel)))
  3. (xdrx_setenttodb e)
  4. (xdrx_modent 2 "solid")
  5. </normalfont>
已领礼包: 593个
发表于 2003-2-23 22:08:20 | 显示全部楼层
最初由 lsjjm 发布
  1. (setq e (vlax-ename->vla-object (car (entsel))))
  2. (vla-setpattern e acHatchPatternTypePreDefined "solid")
联机帮助部分:
  1. Signature
  2. object.SetPattern PatternType, PatternName
  3. Object
  4. Hatch
  5. The object or objects this method applies to.
  6. PatternType
  7. AcPatternType enum; input-only
  8. acHatchPatternTypePreDefined
  9. Selects the pattern name from those defined in the acad.pat file.
  10. acHatchPatternTypeUserDefined
  11. Defines a pattern of lines using the current linetype.
  12. acHatchPatternTypeCustomDefined
  13. Selects the pattern name from a PAT file other than the acad.pat file.
  14. PatternName
  15. String; input-only
  16. The name of the pattern. Sets a default hatch pattern name of up to 34 characters, no spaces
  17. allowed. Returns "" if there is no default. Enter a period (.) to set no default.
  18. Remarks
  19. The hatch pattern can be defined by one of the following options:
  20. PreDefined: Selects the pattern name from those defined in the acad.pat file.
  21. UserDefined: Defines a pattern of lines using the current linetype.
  22. CustomDefined: Selects the pattern name from a PAT file other than the acad.pat file.
 楼主| 发表于 2003-2-25 11:16:08 | 显示全部楼层
两位都用到了(entsel), 在程序中增加了一个手动操作, 相当修改Hatch的Pattern, 能否在Hatch前
预先设置? 且不需手动?
已领礼包: 593个
发表于 2003-2-25 11:36:46 | 显示全部楼层
命令:
SETVAR 输入变量名或 [?]: hpname
输入 HPNAME 的新值 <"ANSI31">: solid
  1. 类型:字符串
  2. 不保存
  3. 初始值:“ANSI31”
  4. 设置默认填充图案,其名称最多可包含 34 个字符,其中不能有空格。如果没有设置默认值,将返回 ""。
  5. 输入句点 (.),将 HPNAME 重置为默认值。
复制代码
发表于 2003-2-25 12:01:08 | 显示全部楼层
(command "setvar" "hpname" "solid")
 楼主| 发表于 2003-2-25 14:19:54 | 显示全部楼层
这回解决了, 谢谢。不过又出现了新问题:HATCH只在我指定的部分区域工作, 如果ZOOM放大就好了, 这是什么问题 ?
GMT+8, 2026-11-3 15:06 , Processed in 0.472403 second(s), 44 queries , Gzip On.
