查看: 905|回复: 4
[求助] [求助]:我这段代码错在哪?(ljpnb已帮忙解决)
发表于 2005-4-5 15:47:48 | 显示全部楼层 |阅读模式
已解决...
发表于 2005-4-5 16:04:16 | 显示全部楼层
我修改过了:
(defun c:test ()                        ;竖直排列网点,单边光源
  (command "osnap" "none")
  (setvar "cmdecho" 0)
  (dcl_dia1)                                ;调用对话框子程序
  (prin1)                                ;防止nil
(defun dcl_dia1        ()
  (setq dcl_id (load_dialog "dia1"))        ;载入DCL文件
  (new_dialog "dia1" dcl_id)                ;启动dia1对话框
  (set_tile "kr1" "0.2")                ;设定r1起始值
  (set_tile "kr2" "0.5")                ;设定b起始值
  (set_tile "kb" "0.8")                        ;设定b起始值
  (set_tile "kh" "0.9")                        ;设定h起始值
  (set_tile "knn" "50")                        ;设定nn起始值
  (set_tile "kgg" "30")                        ;设定gg起始值
  (action_tile "draw_ok" "(get_rbh)(done_dialog 1)")
  (setq dd (start_dialog))
  (if (= dd 1)
    (c:zhipai)
    (t (alert "未完成任何动作!!!"))
(defun get_rbh ()
  (setq r1 (atof (get_tile "kr1")))
  (setq r2 (atof (get_tile "kr2")))
  (setq b (atof (get_tile "kb")))
  (setq h (atof (get_tile "kh")))
  (setq nn (atof (get_tile "knn")))
  (setq gg (atof (get_tile "kgg")))
(defun c:zhipai        ()
  (setq a (/ (- r2 r1) (1- nn)))
  (setq pt1 (getpoint "任选一点:"))
  (setq        i 0
        c 0
  (setq nnn (/ nn b))
  (setq n (fix nnn))
  (setq ggg (/ gg h))
  (setq g (fix ggg))
  (while (<= i n)
    (setq f (nth 0 pt1)
          e (* b i)
    (setq pt (list (+ f e) (nth 1 pt1)))
    (setq d (+ r1 (* a i)))
    (setq i (1+ i))
    (command "circle" pt (/ d 2))        ;用圆形绘制
  )                                        ;while
  (command "array" "all" "" "" (1+ g) 1 h )
  (prin1)
 楼主| 发表于 2005-4-5 16:14:40 | 显示全部楼层
非常谢谢!
除了一个关键错误在setvar "b" 中不改加""号以外,能帮我说明一下哪些地方错了吗?
谢谢!
发表于 2005-4-5 16:24:29 | 显示全部楼层
最关键是这:
(defun get_rbh ()
不是用setvar,而是用setq,setvar是对系统变量进行操作,setq是对一般变量的附值
 楼主| 发表于 2005-4-5 16:29:03 | 显示全部楼层
啊...终于明白了,谢谢ljpnb!!!
原来你在宁波呀,我在慈溪!
呵呵,再次感谢!!!!
kevin
GMT+8, 2026-11-6 02:38 , Processed in 0.427257 second(s), 40 queries , Gzip On.
