查看: 616|回复: 4
[求助]:导出实体问题
已领礼包: 557个
发表于 2005-4-7 09:33:21 | 显示全部楼层 |阅读模式
到处都是怎么插入未打开的图形中的块,我想请问一下怎么把当前图形中的实体输出到未打开的文件中,谢谢
发表于 2005-4-7 12:07:28 | 显示全部楼层
Signature
object.WBlock FileName, SelectionSet
Object
Document
The object or objects this method applies to.
FileName
String; input-only
The file name to write the selection set to.
SelectionSet
SelectionSet object; input-only
The name of the selection set.
已领礼包: 557个
 楼主| 发表于 2005-4-7 14:53:23 | 显示全部楼层
好像输出的新文件就覆盖了旧文件,我的意思是在未打开的文件中添加实体
发表于 2005-4-7 15:24:35 | 显示全部楼层
Sub tt()
On Error Resume Next
    Dim filename As String
    filename = "f:/1.dwg"
    Dim objDbx As Object
    If Left(Version, 2) = "15" Then
        Set objDbx = CreateObject("ObjectDBX.AxDbDocument.1")
    ElseIf Left(Version, 2) = "16" Then
        Set objDbx = CreateObject("ObjectDBX.AxDbDocument.16")
    End If
    objDbx.Open filename
    Dim ss As AcadSelectionSet
    ThisDrawing.SelectionSets("Test").Delete
    Set ss = ThisDrawing.SelectionSets.Add("Test")
    ss.SelectOnScreen
    Dim objs() As AcadEntity
    ReDim objs(ss.Count - 1)
    For i = 0 To ss.Count - 1
        Set objs(i) = ss(i)
    Next i
    ss.Delete
    ThisDrawing.CopyObjects objs, objDbx.ModelSpace
    objDbx.SaveAs filename
End Sub
已领礼包: 557个
 楼主| 发表于 2005-4-7 15:33:32 | 显示全部楼层
谢谢
GMT+8, 2026-11-3 20:13 , Processed in 0.663625 second(s), 40 queries , Gzip On.
