查看: 638|回复: 0
[求助]:请教hellow有关XTP的消息处理的问题!
发表于 2005-4-17 08:41:09 | 显示全部楼层 |阅读模式
一般在XTP里使用CXTPDockingPaneManager这个类里,都要做以下的消息处理!但是在ARX里你如何处理这个消息!谢!
BEGIN_MESSAGE_MAP(CMainFrame, CMDIFrameWnd)
    //{{AFX_MSG_MAP(CMainFrame)
    ON_WM_CREATE()
    //}}AFX_MSG_MAP
    ON_MESSAGE(XTPWM_DOCKINGPANE_NOTIFY, OnDockingPaneNotify)
END_MESSAGE_MAP()
LRESULT CMainFrame::OnDockingPaneNotify(WPARAM wParam, LPARAM lParam)
    if (wParam == XTP_DPN_SHOWWINDOW)
        CXTPDockingPane* pPane = (CXTPDockingPane*)lParam;
        if (!pPane->IsValid())
            switch (pPane->GetID())
            case IDR_PANE_PROPERTIES:
                    if (m_wndProperties.GetSafeHwnd() == 0)
                        m_wndProperties.Create(WS_CHILD|
                            ES_AUTOVSCROLL|ES_MULTILINE,
                            CRect(0, 0, 0, 0), this, 0);
                    pPane->Attach(&m_wndProperties);
                    break;
            case IDR_PANE_OPTIONS:
                    if (m_wndOptions.GetSafeHwnd() == 0)
                        m_wndOptions.Create(_T("\n\nOptions"),
                            WS_CHILD|WS_CLIPCHILDREN|
                            WS_CLIPSIBLINGS|SS_CENTER,
                    pPane->Attach(&m_wndOptions);
                    break;
        return TRUE;
    return FALSE;
GMT+8, 2026-11-6 08:13 , Processed in 0.534708 second(s), 32 queries , Gzip On.
