查看: 1280|回复: 2
[求助] [求助]:SHELL 如何在后台隐藏运行?
发表于 2005-4-23 16:44:50 | 显示全部楼层 |阅读模式
SHELL 如何在后台隐藏运行?
发表于 2005-4-24 20:08:29 | 显示全部楼层
你可以利用wscript的shell, 可以通过activeX口调用。具体可以参考windows script host的资料。
函数原型:
WshShell.Run(strCommand[, [intWindowStyle][, bWaitOnReturn]])
intWindowStyle可以选的值。所谓的后台运行就是Hide吧。
0 vbHide Hides the window. Another window is activated (is shown and gets the focus).
1 vbNormalFocus Activates the window and shows it. If the process is already active and the window is minimized or maximized, the previous size and position are restored.
2 vbMinimizedFocus Activates the window and minimizes it. The button on the taskbar receives the focus.
3 vbMaximizedFocus Activates the window, maximizes it, and gives it the focus.
4 vbNormalNoFocus Displays a window in its most recent size and position. The active window remains active.
5  Activates the window in its current size and position.
6 vbMinimizedNoFocus Minimizes the window and activates the next top-level window in the z-order.
7  Displays the window as an icon (minimized). The active window remains active.
8  Displays the window in its current state. The active window remains active.
9  Activates and displays the window. If a window is minimized or maximized, Windows restores the original size and position. An application should specify this flag when restoring a minimized window. (This parameter can't be used with the Run method.)
10  Sets the show state based on the state of the program that started the application.
给个例子:
  1.   [FONT=courier new]
  2. (setq shell (vlax-create-object "WScript.shell"))
  3. ;; 注,在Windows 9x中calc.exe程序不在本示例中的位置,而在"%WINDIR%\\Calc.exe"
  4. (vlax-invoke-method shell 'run "%WINDIR%\\system32\\Calc.exe" 1 :vlax-true)
  5. (vlax-invoke-method shell 'run "%COMSPEC% /c copy c:\\aaa.lsp c:\\bbb.lsp" 0 :vlax-false)
  6. (vlax-release-object shell)
  7.   [/FONT]
发表于 2005-4-24 20:23:52 | 显示全部楼层
可以简单吗??
GMT+8, 2026-11-6 07:02 , Processed in 0.381233 second(s), 36 queries , Gzip On.
