查看: 2054|回复: 6
[求助]:试图执行系统不支持的操作。
发表于 2005-4-28 11:41:45 | 显示全部楼层 |阅读模式
我的vc 窗体,到了autocad 下,不能显示,报错,试图执行系统不支持的操作。
请各位大虾指点。
发表于 2005-4-28 12:52:56 | 显示全部楼层
资源没有正确切换。
发表于 2005-4-28 20:12:27 | 显示全部楼层
"资源没有正确切换"  是什么意思? 应当如何保证正确切换呢
发表于 2005-4-29 02:33:00 | 显示全部楼层
请在弹出你自己的对话框时加上如下语句:
CAcModuleResourceOverride thisResource;
这是起临时切换资源的作用,如果没有这句话,一般都会提示“unsupported operat"错误。
以下是Arx帮助系统里的说明。
Resource management is an important consideration when designing an ObjectARX application that uses an MFC library shared with AutoCAD and other applications.
You must insert your module state (using CDynLinkLibrary) into the chain that MFC examines when it performs operations such as locating a resource. However, it is strongly recommended that you explicitly manage your application's resources so that they will not conflict with other resources from AutoCAD or other ObjectARX applications.
To explicitly set resources
Before taking any steps that would cause MFC to look for your resource, call the AFX function AfxSetResourceHandle() to set the custom resource as the system default.
Before setting the system resource to your resource, call AfxGetResourceHandle() to get the current system resource.
Immediately after performing any functions that require the custom resource, the system resource should be reset to the resource handle previously saved.
Calling AutoCAD API functions (or invoking AutoCAD commands) inside the dialog command handler that needs AutoCAD's resources, such as acedGetFileD(), sets the resource back to AutoCAD before calling the functions. Restore your application resource afterwards. (Use acedGetAcadResourceInstance() to get AutoCAD's resource handle.)
 楼主| 发表于 2005-4-29 09:58:31 | 显示全部楼层
明白了~谢谢了
发表于 2005-4-30 09:58:10 | 显示全部楼层
资源没有切换,资源不正确,都会出现此种情况
发表于 2005-5-18 12:17:06 | 显示全部楼层
就是,终点检查一下,你对话框上控件的资源id,看是否是数字,我遇到过这样的情况。
GMT+8, 2026-11-6 08:03 , Processed in 0.461093 second(s), 44 queries , Gzip On.
