查看: 481|回复: 2
[求助]:acad2006 简体中文版 ET 安装问题
发表于 2005-5-8 11:24:01 | 显示全部楼层 |阅读模式
为什么我的acad2006简体中文版安装了ET工具 但是找不到
望告之 是不是不支持
发表于 2005-5-8 12:56:59 | 显示全部楼层
I have the AutoCAD Express Tools installed, but I cannot see the Express menu. How can I display this menu?
Use the EXPRESSMENU command.
I can see the Express menu, but I do not see any AutoCAD Express Tools toolbars. How can I display the toolbars?
Use the TOOLBAR command to load the Toolbars dialog box. In the Menu Group list, select EXPRESS. A list of toolbars is displayed. Select the toolbars you want, and then choose Close.
 楼主| 发表于 2005-5-9 09:10:07 | 显示全部楼层
thx  a lot  ! use cad many years,but i know it now ~~~
GMT+8, 2026-8-7 01:34 , Processed in 0.375293 second(s), 36 queries , Gzip On.
