查看: 933|回复: 0
[编程申请]:如何画三维旋转立体图(多义线包含直线和弧线)
发表于 2003-3-11 20:49:34 | 显示全部楼层 |阅读模式
晓东,你好!
我现在有个问题:
我不知道如何画由一条带直线和和弧线组成的多义线旋转而成的三维立体图!
我原先是这样做的:
AcGePoint2dArray pt2d;
AcGeVector3d normal(0.0, 0.0, 1.0);
AcDbPolyline *poly = new AcDbPolyline;
AcGePoint3d moveBy(0, 0, 0);
pt2d.setLogicalLength(8);
pt2d[0].set(x1, y1);
pt2d[1].set(x2, y2);
pt2d[2].set(x3, y3);
pt2d[3].set(x4, y4);
pt2d[4].set(x5, y5);
pt2d[5].set(x6, y6);
pt2d[6].set(x7, y7);
pt2d[7].set(x8, y8);
//其中(xi, yi)代表顶点的坐标
for(int i = 0; i < 8; i++)
poly->addVertexAt(i, pt2d);
poly->setClosed(Adesk::kTrue);
poly->setNormal(normal);
AcDbVoidPtrArray lines, regions;
lines.append((void *)poly);
AcDbRegion::createFromCurves(lines, regions);
AcDbRegion *pRegion = AcDbRegion::cast((AcRxObject *)regions[0]);
AcDb3dSolid *p3dObj = new AcDb3dSolid;
AcGePoint3d axisPoint(0.0, 0.0, 0.0);
AcGeVector3d axisDir(0.0, 1.0, 0.0);
double Revolution = 2.0 * PI;
AcGePoint3d origin(0.0, 0.0, 0.0);
AcGeVector3d x(1, 0, 0), y(0, 1, 0), z(0, 0, 1);
AcGeMatrix3d mat;
if(Acad::eOk == p3dObj1->revolve(pRegion1, axisPoint, axisDir,
Revolution))
mat.setCoordSystem(origin, x, y, z);
p3dObj->transformBy(mat);
delete pRegion1;
//把实体假如数据库
AcDbObjectId p3dObjId = AddEntityToDbs(p3dObj);
p3dObj1->close();
可是,这只能话直线段的封闭多义线的旋转三维图!
恳请晓东帮忙!谢谢!!!
GMT+8, 2026-11-3 15:54 , Processed in 0.481885 second(s), 32 queries , Gzip On.
