查看: 1055|回复: 1
[求助] [求助]:startapp遭遇EXCEL阻击,咋办?
发表于 2005-5-27 10:17:25 | 显示全部楼层 |阅读模式
(startapp   "C:\\Program Files\\Microsoft Office\\OFFICE11\\excel.exe" "D:\\Program Files\\AutoCAD 2002\\myexcel.xls" )
上面代码  启动了excel但是打不开确实存在的myexcel.xlS  ,原因是路径中有空格。
这个是谁错了呢
问题已经解决, 惭愧! 没有仔细阅读帮助:
If an argument has embedded spaces, it must be surrounded by literal double quotes. For example, to edit the file my stuff.txt with Notepad, use the following syntax:
Command: (startapp "notepad.exe" "\"my stuff.txt\"")
已领礼包: 3256个
发表于 2017-11-5 11:01:35 | 显示全部楼层
回帖是一种美德!感谢楼主的无私分享 谢谢
GMT+8, 2026-11-5 14:42 , Processed in 0.429032 second(s), 34 queries , Gzip On.
