查看: 1019|回复: 0
[LISP函数]:大侠帮帮忙,给予指点
发表于 2005-5-29 18:05:02 | 显示全部楼层 |阅读模式
输出CAD的文本框中的信息到EXCEL中,但下面的程序出了错误,请指点!
(Defun C:SPLL()
       (PrinC "\n这是对 Spline 进行数据分析的基本程序...")
       (While(progn(setq pen(car(entsel "\n指定一条 Spline: ")))
                        (/= "SPLINE"(cdr(assoc 0 (entget pen))))
                (Alert "所指对象不是 Spline,请重新指定...")
  (setq ent(entget pen))
  (setq ct 0)
  (textpage)
  (princ"\n 拟合点的坐标值:")
  (setq c1(length ent))
  (while(< ct c1)
   (setq d2(car(nth ct ent)))
      (if(= 10 d2)
        (progn
          (setq d3(cdr(nth ct ent)))
          (print d3)
   (setq ct(+ 1 ct))
  (print)
(vl-load-com)
(defun DSX-TypeLib-Excel ( / sysdrv tlb)
(setq sysdrv (getenv "systemdrive"))
(cond
( (setq tlb (findfile (strcat sysdrv "\\Program Files\\Microsoft Office\\Office\\Exce2003.olb")))
tlb
( (setq tlb (findfile (strcat sysdrv "\\Program Files\\Microsoft Office\\Office\\Excel9.olb")))
tlb
( (setq tlb (findfile (strcat sysdrv "\\Program Files\\Microsoft Office\\Office\\Excel10.olb")))
tlb
( (setq tlb (findfile (strcat sysdrv "\\Program Files\\Microsoft Office\\Office\\Excel.exe")))
tlb
( (setq tlb (findfile (strcat sysdrv "\\Program Files\\Microsoft Office\\Office10\\Excel.exe")))
tlb
(defun DSX-Load-TypeLib-Excel ( / tlbfile tlbver out)
(cond
( (null msxl-xl24HourClock)
(if (setq tlbfile (DSX-TypeLib-Excel))
(progn
(setq tlbver (substr (vl-filename-base tlbfile) 6))
(cond
( (= tlbver "9")
(princ "\n初始化 Microsoft Excel 2003...") )
( (= tlbver "8")
(princ "\n初始化 Microsoft Excel 97...") )
( (= (vl-filename-base tlbfile) "Excel.exe")
(princ "\n初始化 Microsoft Excel XP...")
(vlax-import-type-library
:tlb-filename tlbfile
:methods-prefix "msxl-"
:properties-prefix "msxl-"
:constants-prefix "msxl-"
(if msxl-xl24HourClock (setq out T))
( T (setq out T) )
out
(defun DSX-Open-Excel-New (dmode / appsession)
(princ "\n创建一个新的 Excel 电子表格文件...")
(cond
( (setq appsession (vlax-create-object "Excel.Application"))
(vlax-invoke-method (vlax-get-property appsession 'WorkBooks) 'Add)
(if (= (strcase dmode) "SHOW")
(vla-put-visible appsession 1)
(vla-put-visible appsession 0)
appsession
(defun DSX-Excel-Put-ColumnList (lst startrow startcol)
(foreach itm lst
(msxl-put-value
(DSX-Excel-Get-Cell range startrow startcol)
itm
(setq startrow (1+ startrow))
); repeat
(defun DSX-Excel-Put-RowList (lst startrow startcol)
(foreach itm lst
(msxl-put-value
itm
(setq startcol (1+ startcol))
); repeat
GMT+8, 2026-11-6 09:03 , Processed in 0.432887 second(s), 32 queries , Gzip On.
