查看: 1237|回复: 0
[ARX程序]:请教:在Arx退出AutoCAD系统!
发表于 2002-4-18 23:22:12 | 显示全部楼层 |阅读模式
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
switch (msg) {
    case AcRx::kInitAppMsg:
      // Comment out the following line if your
    // application should be locked into memory
    acrxDynamicLinker->unlockApplication(pkt);
    acrxDynamicLinker->registerAppMDIAware(pkt);
    if(StartLogin())//这里要怎样处理,目的:假如登录失败就退出系统,函数实现在下面
        InitApplication();
     break;
     case AcRx::kUnloadAppMsg:
          UnloadApplication();
         break;
   return AcRx::kRetOK;
我用上面那样写退出后会提示异常
//函数实现
CLoginDlg dlg;  登录窗体类
int iRes=dlg.DoModal();
if(iRes!=IDOK)
    //退出系统
   acedCommand(RTSTR,"QUIT",RTSTR,"Y",0);
    return false;
GMT+8, 2026-11-22 11:02 , Processed in 0.291860 second(s), 11 queries , Gzip On, File On.
