查看: 770|回复: 0
[求助]:帮忙看一下,下面代码错在哪里?
发表于 2003-3-15 19:03:06 | 显示全部楼层 |阅读模式
//本程序意图让操作者选定一个实体,接着判断实体类型,若是非AcDb3dSolid,设置为黄色,并点亮后恢复
若是AcDb3dSolid,设置为红色,整体点亮后恢复。
然后打开GS为2的第一个面,并点亮此面,最后想法向拉伸此面60个单位。
构建编译时出现错误为:
cdcd.cpp
f:\cdcd\cdcd.cpp(76) : error C2664: 'extrudeFaces' : cannot convert parameter 1 from 'class AcDbSubentId *' to 'const class AcArray<class AcDbSubentId *,class AcArrayMemCopyReallocator<class AcDbSubentId *> > &'
        Reason: cannot convert from 'class AcDbSubentId *' to 'const class AcArray<class AcDbSubentId *,class AcArrayMemCopyReallocator<class AcDbSubentId *> >'
        No constructor could take the source type, or constructor overload resolution was ambiguous
Error executing cl.exe.
CDCD.ARX - 1 error(s), 0 warning(s)
我对此不是很了解
cyb恳请大家帮忙解决,最好有具体的修正后的代码.
非常感谢!
void
cybobj()
    ads_name en;
    ads_point pt;
    if (acedEntSel("\n选取一实体: ", en,pt) != RTNORM)
        acutPrintf("\n没有选取");
        return;
            AcDbObjectId eId;
            acdbGetObjectId(eId, en);
        AcDbEntity *pEnt;
        acdbOpenAcDbEntity(pEnt, eId, AcDb::kForWrite);
    if (pEnt->isKindOf(AcDb3dSolid::desc())) {
            pEnt->close();
        AcDb3dSolid *box;
            acdbOpenObject(box, eId, AcDb::kForWrite);
        box->setColorIndex(1);
        box->highlight();
        pressEnterToContinue();
        box->unhighlight();
        AcGePoint3d pickpnt;
            AcGeMatrix3d xform;
            int numIds;
            AcDbFullSubentPath *subentIds;
        box->getSubentPathsAtGsMarker(AcDb::kFaceSubentType,
      2, pickpnt, xform, numIds, subentIds);
        box->highlight(subentIds[0]);//显亮此面
        pressEnterToContinue();//回车键继续
        box->unhighlight(subentIds[0]);//不显亮
        box->extrudeFaces(&subentIds[0].subentId(),60,0);
        //想沿法向拉伸此面60,--------此行出现错误。(第一个参数类型不对)
        box->close();
    acutPrintf("\n所选是三维实体");
        else {
                pEnt->setColorIndex(2);
                pEnt->highlight();
                pEnt->unhighlight();
                pEnt->close();
        acutPrintf("\n所选不是三维实体");
GMT+8, 2026-11-3 11:11 , Processed in 0.439509 second(s), 32 queries , Gzip On.
