查看: 1253|回复: 4
[求助] [求助]:有关字符串的问题
发表于 2005-6-8 08:21:17 | 显示全部楼层 |阅读模式
我现在想提取字符串"600×200"中的600和200两个数,其中×是用软键盘输入的.请问有什么方法吗?
我用下面的程序来实现,可读到×时就不好用了,而用*这个乘号就好使,这是什么原因呀?
(setq i 2)
  (setq a (substr gh 1 1))
  (while (/= (substr gh i 1) "×")
    (setq a (strcat a (substr gh i 1)))
    (setq i (1+ i))
  (setq b (substr gh i))
已领礼包: 12493个
发表于 2005-6-8 13:08:39 | 显示全部楼层
"×"是全角字符,用(substr gh i 1)取到的是半角字符当然不行了。
应该用(substr gh i 2)画取字符。即:
(setq i 1)
(setq a (substr gh 0 1)
(while (/= (substr gh i 2) "×")
  (setq i (1+ i))
(setq b (substr gh (1+ i)))
发表于 2005-6-8 13:44:37 | 显示全部楼层
[php];(test "6002×23200")
(defun test(gh)
  (setq i 1)
    (setq a (substr gh 1 i)
          i (1+ i)
  (setq b (substr gh (+ i 2)))
  (princ "\n前 = ")(princ a)
  (princ "\n后 = ")(princ b)
  (princ)
)[/php]
 楼主| 发表于 2005-6-8 14:56:56 | 显示全部楼层
谢谢大家
已领礼包: 111个
发表于 2005-7-2 10:16:50 | 显示全部楼层
;Command: (zffl "600×200")
;(600 200)
(defun zffl(zfc)
  (read (strcat "(" (vl-string-subst " " "×" zfc) ")"))
GMT+8, 2026-11-6 09:14 , Processed in 0.404523 second(s), 40 queries , Gzip On.
