查看: 820|回复: 0
[ARX程序]:如果复制AcDb2dPolyline ?
发表于 2003-3-17 09:12:06 | 显示全部楼层 |阅读模式
当我查看帮助中的实体复制函数getTransformedCopy时,发现下面的提示:
Warning For AutoCAD built-in complex entities such as polylines, this function produces a shallow clone of the header entity only, which also owns the original set of "owned" entities (such as vertices for a polyline) which are then transformed by the xform matrix. This results in a corrupt drawing (two header entities owning the same set of "owned" entities) as well as transforming the original set of "owned" entities instead of a copied set.
这里好象是说,多段线实体不能通过该函数获得完全独立实体。请问高手我想复制一个独立的多段线实体,该如何做?
GMT+8, 2026-11-3 11:13 , Processed in 0.451308 second(s), 30 queries , Gzip On.
