查看: 965|回复: 2
[编程申请]:把一个目录下的多个图形拼成一张图
发表于 2005-6-16 12:02:10 | 显示全部楼层 |阅读模式
如何把一个目录下的多个图形拼成一张图,不用手工一张一张插入,程序代码怎么编
发表于 2005-6-16 12:32:09 | 显示全部楼层
  1. (defun c:fileddinsert (/ file dir FILE-J N I)
  2.   (setq file (getfiled "" "" "dwg" 4))
  3.   (if (= file nil)
  4.     (exit)
  5.     (progn
  6.       (setq dir (vl-filename-directory file))
  7.       (SETQ FILE-J (vl-directory-files DIR "*.DWG"))
  8.       (SETQ I 0)
  9.       (SETQ N (LENGTH FILE-J))
  10.       (REPEAT N
  11.           (SETQ FILE (NTH  I FILE-J))
  12.           (SETQ FILE (STRCAT DIR "\" FILE))
  13.           (COMMAND "-INSERT" FILE '(0 0) 1 1 0)
  14.           (SETQ I (1+ I))
  15.         )
  16.     )
  17.   )
  18. )
 楼主| 发表于 2005-6-17 00:11:31 | 显示全部楼层
很好用,谢谢xiao_longxin 大侠!
GMT+8, 2026-11-6 09:13 , Processed in 0.402847 second(s), 36 queries , Gzip On.
