查看: 884|回复: 2
[VBA函数]:轻松指定多种过过虑,在屏幕选定选择集
发表于 2003-3-21 22:48:28 | 显示全部楼层 |阅读模式
以下为一在屏幕选取物体程序,大家可在程序段中加入这一代码,可轻松过滤多种绘图对象,
请各位多多指教。
Public Sub selection()
    Dim SSet As AcadSelectionSet
    Dim GroupCode(0 To 4) As Integer
    Dim DataValue(0 To 4) As Variant
    MsgBox "选择圆弧、圆、椭圆等图形"
On Error Resume Next
' 如果出现该选择集则把它删除
If Not IsNull(ThisDrawing.SelectionSets.Item("ArcsCirclesEllipses")) Then
    Set SSet = ThisDrawing.SelectionSets.Item("ArcsCirclesEllipses")
    SSet.Delete
End If
    Set SSet = ThisDrawing.SelectionSets.Add("ArcsCirclesEllipses")
    'Setup Selection Set Filter
    GroupCode(0) = -4
    DataValue(0) = "<or"
    GroupCode(1) = 0
    DataValue(1) = "Arc"        '圆弧,可以更换为Line、Spline等
    GroupCode(2) = 0
    DataValue(2) = "Circle"     '圆,可以更换,类型同上。
    GroupCode(3) = 0
    DataValue(3) = "Ellipse"    '椭圆,可以更换,类型同上。
    GroupCode(4) = -4
    DataValue(4) = "or>"
    SSet.SelectOnScreen GroupCode, DataValue
End Sub
发表于 2006-2-7 15:23:53 | 显示全部楼层
VBA帮助里面就有,全多了
发表于 2006-2-7 19:27:40 | 显示全部楼层
你没有试过这样?
Dim GroupCode(0) As Integer
Dim DataValue(0) As Variant
GroupCode(0) = 0
DataValue(0) = "Arc,Circle,Ellipse"
GMT+8, 2026-11-3 00:31 , Processed in 0.920288 second(s), 35 queries , Gzip On.
