查看: 819|回复: 6
[求助]:怎样用CAD 画塔形弹簧的实体
发表于 2005-7-13 20:06:01 | 显示全部楼层 |阅读模式
各位高手,小弟近日碰到 一个难题,就要要用CAD画实体的锥形弹簧,小弟水平有限,实在没有办法,请各位高手不吝赐教,拔刀相助,在下先谢恩了*-*3
发表于 2005-7-13 20:56:40 | 显示全部楼层
命令a1、a2
每圈点数可以调节精度
(defun myerror (s)
  (if (/= s "Function cancelled")
    (princ (strcat "\n错误: " s))
  (setvar "cmdecho" ocmd)             ; 恢复已保存的模式
  (setvar "blipmode" oblp)
  (setq *error* olderr)               ; 恢复旧的*error* 句柄
  (princ)
(defun cspiral (ntimes bpoint hfac lppass strad vfac
                / ang dist tp ainc dhinc dvinc circle dv)
  (setvar "blipmode" 0)               ; 关闭blipmode
  (setvar "cmdecho" 0)                ; 关闭cmdecho
  (setq circle (* 3.141596235 2))
  (setq ainc (/ circle lppass))
  (setq dhinc (/ hfac lppass))
  (if vfac (setq dvinc (/ vfac lppass)))
  (setq ang 0.0)
  (if vfac
    (setq dist strad dv 0.0)
    (setq dist 0.0)
  (if vfac
    (command "3dpoly")                ; 开始绘制螺旋线 ...
    (command "pline" bpoint)          ; 开始从基点绘制螺旋线并...
  (repeat ntimes
    (repeat lppass
      (setq tp (polar bpoint (setq ang (+ ang ainc))
                      (setq dist (+ dist dhinc))
      (if vfac
          (setq tp (list (car tp) (cadr tp) (+ dv (caddr tp)))
                dv (+ dv dvinc)
      (command tp)                    ; 继续到下一点...
  (command "")                        ; 直到完成。
  (princ)
;Interactive spiral generation
(defun C:a1 (/ olderr ocmd oblp nt bp cf lp)
  ;(setq olderr  *error*
  ;      *error* myerror)
  (setq ocmd (getvar "cmdecho"))
  (setq oblp (getvar "blipmode"))
  (initget 1)                         ; bp不必为空
  (setq bp (getpoint "\n中心点: "))
  (initget 7)                         ; nt不必为零、负或空
  (setq nt (getint "\n圈数: "))
  (initget 3)                         ; cf不必为零或空
  (setq cf (getdist "\n步长: "))
  (initget 6)                         ; lp不必为零或负
  (setq lp (getint "\n每圈点数 <30>: "))
  (cond ((null lp) (setq lp 30)))
  (cspiral nt bp cf lp nil nil)
  (princ)
(defun C:a2 (/ olderr ocmd oblp nt bp hg vg sr lp)
  ;      *error* myerror)
  (initget 1)                         ; bp不必为null
  (initget 7)                         ; sr不必为零、负或空
  (setq sr (getdist bp "\n起始半径: "))
  (initget 1)                         ; cf不必为零或空
  (setq hg (getdist "\n水平步长: "))
  (setq vg (getdist "\n垂直步长: "))
  (cspiral nt bp hg lp sr vg)
  (princ)
(princ)
 楼主| 发表于 2005-7-14 08:25:05 | 显示全部楼层
在此感谢贱人的帮忙,只可惜我用的是AUTOCAD2004中文版,有点看不明白
发表于 2005-7-14 08:39:36 | 显示全部楼层
a1可以画平面螺旋线,a2可以画塔形螺旋线,画完在段点画个圆,沿路径拉伸就好了
和cad版本没什么关系吧,我也是2004
发表于 2005-7-14 13:18:27 | 显示全部楼层
我还是看不明白啊
 楼主| 发表于 2005-7-15 01:11:21 | 显示全部楼层
我用的是AUTODESK公司的AUTOCAD2004呀,不是什么天正和什么中旺呀
发表于 2005-7-21 23:02:55 | 显示全部楼层
感谢贱人的程序
GMT+8, 2026-11-6 02:41 , Processed in 0.496922 second(s), 45 queries , Gzip On.
