查看: 1171|回复: 10
[求助] [求助]:画角钢平面图
发表于 2005-7-16 01:09:27 | 显示全部楼层 |阅读模式
经常画角钢结构平面图,那位DX能不能提供程序,一笔旧画出角钢的中心线、边线、虚线。
发表于 2005-7-18 02:41:44 | 显示全部楼层
想了一下,
需要输入一下条件(交互输入)
肢长(b)/壁厚(h)/正反(z)/上下(p)/<下一点:>
发表于 2005-7-18 03:24:06 | 显示全部楼层
先来个简单的:
[php]
(defun C:jiaogang ()
  (setq oldla (getvar "CLAYER"))
  (setq pt1 (getpoint "\n角钢的起点:"))
  (setq pt2 (getpoint pt1 "\n角钢的下一点:"))
  (setq        pt3 (polar pt1 (+ (angle pt1 pt2) (* 0.5 pi)) 35)
        pt4 (polar pt1 (+ (angle pt1 pt2) (* 1.5 pi)) 15)
        pt5 (polar pt2 (+ (angle pt1 pt2) (* 0.5 pi)) 35)
        pt6 (polar pt2 (+ (angle pt1 pt2) (* 1.5 pi)) 15)
        pt7 (polar pt4 (+ (angle pt1 pt2) (* 0.5 pi)) 5)
        pt8 (polar pt6 (+ (angle pt1 pt2) (* 0.5 pi)) 5)
  (command "layer" "m" "角钢中心线" "c" 1 "" "")
  (command "line" pt1 pt2 "")
  (command "layer" "m" "角钢" "c" 2 "" "")
  (command "line" pt3 pt4 pt6 pt5 "c")
  (command "layer" "m" "角钢肢" "c" 4 "" "")
  (command "line" pt7 pt8 "")
  (setvar "CLAYER" oldla)
[/php]
发表于 2005-7-18 09:16:48 | 显示全部楼层
很多结构的外挂程序都可以,asde和tssd推荐!
 楼主| 发表于 2005-7-18 10:43:46 | 显示全部楼层
非常感谢大家!但我在加载zhynt的软时运行CLAYER时,命令行提示“输入CLAYER的新值<"0">”,然后试输数字或点坐标显示无效,鼠标在屏幕上也不起作用,不知如何使用,麻烦zhynt斑竹在告知。
发表于 2005-7-18 22:44:25 | 显示全部楼层
用"jiaogang"命令运行
 楼主| 发表于 2005-7-18 23:11:19 | 显示全部楼层
再次感谢热心的zhynt斑竹!我用jiaogang成功了,zhynt斑竹不愧为当代活雷锋!!
发表于 2005-7-19 06:13:09 | 显示全部楼层
这程序无尺寸标注能不能编一个角钢断面.
发表于 2005-7-20 00:49:26 | 显示全部楼层
[php]
(defun C:jiaogang (/ pt1 pt2 pt3 pt4 oldla oldos)
  (setq cmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (if (= (tblsearch "LTYPE" "center") nil)
    (command "linetype" "l" "center" "" "")
  (if (= (tblsearch "LTYPE" "dashed") nil)
    (command "linetype" "l" "dashed" "" "")
  (defun init ()
    (if        (= kuandu nil)
      (setq kuandu 50)
    (if        (= sc nil)
      (setq sc 10)
    (if        (= sx nil)
      (setq sx 1)
    (if        (= zf nil)
      (setq zf 1)
  (init)
  (setq oldos (getvar "osmode"))
  (SETQ        pt1 (getpoint "\n指定起点:")
  (setq pt2 t)
  (while (and (/= pt2 "X") (/= pt2 "x") (/= nil))
    (prompt (strcat "\n当前:[宽度:"
                    (rtos kuandu)
                    "][比例:1:"
                    (rtos sc)
                    "][角钢肢在"
                    (if        (= sx 0)
                      "上面"
                      "下面"
                    "][角钢的"
                    (if        (= zf 1)
                      "正面"
                      "反面"
                    "画法]"
    (initget "W S A Z X")
    (setq
      pt2
       (getpoint
         pt1
         "\n指定下一点或 [宽度(W)/比例(S)/上下(A)/正反(Z)/退出(X)]:"
    (cond
      ((= pt2 "W")
       (setq kuandu (getreal "\n输入角钢的宽度<50>"))
      ((= pt2 "S")
       (setq sc (getreal "\n输入绘制比例1:<10>"))
      ((= pt2 "A")
       (setq sx (getreal "\n角钢肢在下面(1)/在上面(0):<1>"))
      ((= pt2 "Z")
       (setq zf (getreal "\n角钢是正(1)/还是反(0):<1>"))
      ((listp pt2)
       (if (/= pt2 nil)
         (progn
           (init)
           (if (= sx 1)
             (setq ang (angle pt1 pt2))
             (setq ang (angle pt2 pt1))
           (setvar "osmode" 0)
                    1             ""              "lt"     "center"        ""
           (command "line"
                    (polar pt1
                           (+ ang (* 0.5 pi))
                           (* (/ 100.0 sc) (/ (* 7 kuandu) 10.0))
                                     (+ ang (* 1.5 pi))
                                     (* (/ 100.0 sc) (/ (* 3 kuandu) 10.0))
                    (setq pt4 (polar pt2
                                     (+ ang (* 1.5 pi))
                    (polar pt2
                           (+ ang (* 0.5 pi))
                    "c"
           (if (= zf 1)
             (command "layer" "m" "角钢肢正" "c" 4 "" "")
             (command "layer"  "m"        "角钢肢反"          "c"
                      4               ""        "lt"         "dashed" ""
           (command "line"
                    (polar pt3 (+ ang (* 0.5 pi)) (* (/ 100.0 sc) 5))
                    (polar pt4 (+ ang (* 0.5 pi)) (* (/ 100.0 sc) 5))
           (setq pt1 pt2)
           (setvar "osmode" oldos)
           (setvar "cmdecho" cmd)
[/php]
发表于 2005-7-20 07:18:55 | 显示全部楼层
斑竹
    我用了怎么还是不能标注大小呢?最好有角钢断面.
发表于 2005-7-20 17:47:10 | 显示全部楼层
角钢心线和厚度可以输入调整吗?
GMT+8, 2026-11-6 10:17 , Processed in 0.475077 second(s), 52 queries , Gzip On.
