查看: 1493|回复: 1
[下载]:提供两个本人认为比较好的扩展小程序
发表于 2002-4-23 01:35:50 | 显示全部楼层 |阅读模式
Infosnap和Quicksnap这是两个与捕捉方式相关的.
注意这两个程序全是适用于J7的,在V8下不能正常运行.设置很简单,大家可以先装载一下看看,如感兴趣或有什么疑问可以跟贴,我会稍作一些解释的.
如果大家想让它们自动随MS一起加载,请将之拷至
E:\V7\Program\MicroStation\mdlsys\required目录下
希望对大家有点帮助.
 楼主| 发表于 2002-4-24 23:01:32 | 显示全部楼层
这是我找到的InfoSnap的技术文档,如果大家有兴趣可以看一下
InfoSnap/J v2.1d for MicroStation/J                                  Alta, Oct 05, 1999
Platform:      Intel Windows (98, NT)
InfoSnap, Public Domain Edition   Copyright (C) 1997,1999 Team uStation AB
Author: Chris Zakrewsky           Copyright (C) 1997,1999 CAD Perfect Dev. Lab
                                  Alta Strandvag 37B
                                  S-138 33 ALTA
                                  S W E D E N
                                  Int'l fax: +46 8 773 3004
                                  E-mail: chris@cadperf.se
PURPOSE:
        InfoSnap is a transparent, background utility that gives you the whole
        new way to see all the information about the element where your
        Tentative-Point go to.
        It works regardless of whether you work in 2D or 3D.
        The DGN element information is gathered and displayed at cursor
        position, in contrast to standard MicroStation GUI that scatters bits
        and pieces of information all over the place.
        And with InfoSnatch you can use this information in your next action.
        You can make a new element same length, direction, level or color.
        Or if the element resides in a reference file, you can make that file
        the active one for edit.
        All with only two key-strokes: down-arrow + ins.
        You should see your productivity raising right away.
NEW IN VERSION:
        1.1
                NEW:     File Position
                NEW:     Graphic Group
                NEW:     Measure Units (MU, WU, User Units)
                FIXED:   Cell levels handling improved (level range)
        1.2
                NEW:     Network installation
        1.3
                NEW:     Self-referenced-file indicator
                NEW:     Style Number or Name
                NEW:     Level Name
                NEW:     Snap Mode
                NEW:     Mute toggle
                NEW:     Key-in interface
        1.4
                NEW:         Compact-size secondary settings box
                FIXED:   New layout of the main Settings dialog box
                NEW:     A delay before banner display (parameter in seconds)
                NEW:     Additional info for Text and Text Nodes (metrics)
                NEW:         Echo to Error Field in Command box
                NEW:         Nested Cell names
                CHANGED: 'SaveSettings' key-in is redefined.
                NEW:     To save settings:    INFOSNAP SAVE
                NEW:     To recall settings:  INFOSNAP RECALL
                CHANGED: 'Type' key-in is redefined.
                NEW:     To see element type name:   INFOSNAP NAME [on|off]
                NEW:     To see element type number: INFOSNAP TYPE [on|off]
        1.5
                NEW:         Accuracy (readout) setting for all numeric output
                NEW:         X, Y, Z coordinates reporting (in current units)
                NEW:         User defined balloon-banner offset from cursor
                FIXED:   Problem with network installation on Read-Only volume
                CHANGED: Auto-open for small Settings box (main box is quiet)
        1.6
                NEW:         Indicate bulk-operations: Fence, Sel. Set, GG-Lock ON
                FIXED:   Coordinates relative to moved Global Origin (GO=)
                CHANGED: Symbology: true or WYSIWYG (view with Level Symbology)
        1.7
                NEW:         Selectable color schemas for the banner popup
                NEW:         Selectable font type for the banner popup
                NEW:         Banner popup can be displayed as a vertical table!
                NEW:         Element tags can be displayed within popup
                NEW:         Display of Z-coordinate range (high & low)
                NEW:         Element lock status
                NEW:         Active Level indicator
                NEW:         For old legacy files (offically unsupported feature!):
                         LINEWIDTH display (in 2D): turn 'Z coordinate' = ON,
                         'Z range' = OFF
                CHANGED: 'echo' can be directed to MicroStation title bar now
                CHANGED: 'Mute' will not disable echoing ('echo'-option).
                         It will affect the popup window only.
                CHANGED: Tens of small tune-ups for enhanced readability
        1.8
                NEW:         Text Justification reporting
                NEW:         Option for text contents reporting for Text Elements
                NEW:         Option for full file-path reporting
                NEW:         Option for reporting complex element components
                NEW:         Option for Compact pop-up layout
                FIXED:   Stability issues on DOS platform
                FIXED:   Contrast issue in 'Background' color scheme
                FIXED:   Display interference with AccuDraw
                FIXED:   Performance interference with fence operations
                FIXED:   Difficulty with accepting Tentative-point over pop-up
                CHANGED: 'Snap Modes' are shown as cursor icon
                CHANGED: 'Active Level' is shown as cursor icon text
                CHANGED: 'Bulk-Ops' are indicated as rectangle around cursor
        1.9p
                NEW:         NEW MicroStation Message-Snatcher (Measurement, etc.)
                NEW:         Arc, Circle and Ellipse metrics
                NEW:         Working Units & Coordinate Readout in uStn title bar
                NEW:         User defined pop-up message (INFOSNAP SNATCHUSER message)
                NEW:         Popup message in macro (INFOSNAP SNATCHOUTPUT uStn_field)
                CHANGED: 'Echo' has immediate effect now, regardless of 'Delay'
                CHANGED: Immediate Reset/Accept after snap will inhibit the
                         pop-up when 'Delay' is larger than zero
                CHANGED: Coordinate and angle readout is improved
                REMOVED: 'Active Level','Bulk-Ops', 'Snap Mode' are no longer
                          part of this utility.
                          For more information, see InfoGlider documentation.
        2.0g
                NEW:         Reusable-settings Snatcher (symbology and metrics).
                NEW:         Precedence setting for Message-Snatcher and Element Info
                         balloons.
                NEW:         Option of triggering Message Snatcher by each data point.
                NEW:         Line Spacing added to Text-Node readout metrics.
                FIXED:   Wrong Area readout in 'uStn readout'-mode.
                FIXED:   Consecutive snaps at the same location wouldn't trigger
                         balloon. This uStn deficiency is now worked around.
        2.1b
                NEW:         Command for reversing file change by Settings Snatcher.
                FIXED:   Setting Snatcher caused exception when reference file
                         had name beginning with a digit.
                FIXED:   AccuDraw Shortcuts were disabled when balloon was open.
                         The same affected AccuDraw keyboard focus.
                FIXED:   Intermitent problem with pop-up balloon appearing on
                         wrong screen (in some dual-head Windows NT configurations).
                FIXED:   Intermitent aborts when Main Settings dialog box was closing.
        2.1c
                FIXED:   Resolved compatibility issues with MicroStation/J.
        2.1d
                FIXED:   Resolved compatibility issues with TriForma.
INSTALLATION:
        Unzip and copy INFOSNAP.MA to your \USTATION\MDLAPPS directory.
        Start MicroStation and go to:
                Workspace->Configuration->Design_Applications
        Locate INFOSNAP in the "Available Applications" list and add it to
        "Applications To Load" list.
        Exit the Workspace Configuration with the Save when prompted.
        Open any DGN file and InfoSnap will pop up.
        That's it.
        Now, snap (Tentative Point) to anything. Voila!
NETWORK INSTALLATION:
        Define MicroStation environment variable INFOSNAP_SETTINGS pointing
        to the directory where the local settings should be stored on local
        machine(s). Give the path only, do not specify the file name.
        Settings file (INFOSNAP.DAT) will be created whenever you push
        "Save"-button in main InfoSnap Settings dialog box.
        Example:
                Workspace->Configuration->New...
                Variable: INFOSNAP_SETTINGS
                New Value: $(MS_SETTINGSDIR)
FINE-TUNING:
        The Setup Dialog box can be recalled with key-in: INFOSNAP SETTINGS.
        Press "Settings"-button to open main Settings dialog box.
        Once there, create your favorite selection of what you want to be
        displayed (and how) when snapping with Tentative Points. Make your
        choice permanent by pressing the "Save"-button.
        Note, that unless you save settings at least once, InfoSnap will
        warn you and use the default values.
        The keyboard-way to change settings is through command key-ins:
        Key-in                                      Purpose
   Static Snap stuff:
        INFOSNAP SHOW FILENUMBER  [ON|OFF]    Reference File attachment
        INFOSNAP SHOW FILENAME    [ON|OFF]    Design file name and extension
        INFOSNAP SHOW FULLPATH    [ON|OFF]    Prefix file name with full path
        INFOSNAP SHOW FILELOGICAL [ON|OFF]    Reference file logical name
        INFOSNAP SHOW FILEPOS     [ON|OFF]    Element file position
        INFOSNAP SHOW TYPE          [ON|OFF]    Element type number
        INFOSNAP SHOW NAME          [ON|OFF]    Element type name
        INFOSNAP SHOW LEVELNUMBER [ON|OFF]    Level or level range (cells)
        INFOSNAP SHOW LEVELNAME   [ON|OFF]    Level name
        INFOSNAP SHOW COLOR          [ON|OFF]    Element color
        INFOSNAP SHOW WEIGHT      [ON|OFF]    Element weight
        INFOSNAP SHOW FONTNUMBER  [ON|OFF]    Font number and text metrics
        INFOSNAP SHOW TEXTSTRING  [ON|OFF]    Follow up font metrics with text
        INFOSNAP SHOW STYLE          [ON|OFF]    Line style number (or name)
        INFOSNAP SHOW GGROUP      [ON|OFF]    Graphic Group
        INFOSNAP SHOW CELLNAME    [ON|OFF]    Show cell name
        INFOSNAP SHOW CELLNEST    [ON|OFF]    List nested cells too (max 5)
        INFOSNAP SHOW ANGLE          [ON|OFF]    Angle projected on three planes
        INFOSNAP SHOW LENGTH      [ON|OFF]    Total length of circumference
        INFOSNAP SHOW AREA          [ON|OFF]    Closed element area
        INFOSNAP SHOW X                  [ON|OFF]    Display x-coordinate
        INFOSNAP SHOW Y                  [ON|OFF]    Display y-coordinate
        INFOSNAP SHOW Z                  [ON|OFF]    Display z-coordinate
        INFOSNAP SHOW TAGS          [ON|OFF]    Tag sets, names and values
   Settings Snatcher stuff:
        INFOSNAP POPFILE                        Undo last file exchange triggered
                                              by INSERT-selection of reference file
   Message Snatcher stuff:
        INFOSNAP SNATCHUSER          [your_message_goes_here]
                                        Display user message. For use in macro.
        INFOSNAP SNATCHOUTPUT     [MESSAGE|STATUS|COMMAND|PROMPT|ERROR]
                                          Echo this field now. For use in macro.
        INFOSNAP SNATCHFIELD          [MESSAGE|STATUS|PROMPT|ERROR|NONE]
                                        Target field to be snatched (echoed).
   General Settings stuff:
        INFOSNAP SNATCHKEY          [SHIFT|CTRL|ALT|CS|CA|AS] Triggering key
        INFOSNAP SNATCHKEY          [DP|RE]     Triggering action        (DataPt or Reset)
        INFOSNAP DISPLAYUNITS     [ON|OFF]    Units & Readout in uStn title bar
        INFOSNAP SETUNITS         [U|W|M|S]   Readout for XYZ, Length & Area
        INFOSNAP DIVISOR          [value]     User Unit definition
        INFOSNAP DELAY            [seconds]   Wait period before banner
        INFOSNAP MUTE             [ON|OFF]    Inhibit InfoSnap
        INFOSNAP POPUP            [ON|OFF]    Auto-open dialog on file exchange
        INFOSNAP TRUESYMB         [ON|OFF]    Always ignore Level Symbology
        INFOSNAP EXACT            [ON|OFF]    Show component of complex element
        INFOSNAP ACCURACY         [0|1|2|3|4|5|6]  Accuracy of readout
        INFOSNAP FONT             [DIALOG|BOLD|FIXED|FIXEDBOLD] Font type
        INFOSNAP FORMAT           [TABLE|BANNER|COMPACT|MICRO]  Pop-up window type
        INFOSNAP ECHO             [NONE|TOP|BOTTOM] Echo banner to other field
        INFOSNAP SAVE                              Save Settings
        INFOSNAP RECALL                              Recall Settings (if saved)
        Note: all [ON|OFF] type key-ins work as toggles when issued without
              ON or OFF modifier.
ADVANCED FINE-TUNING:
        Some graphic drivers report incorrect origin of the screen to InfoSnap
        in dual-screen Windows setup, causing the pop-up banner being shifted
        abnormally (ideally, it should open at very close proximity of cursor).
        Now you can compensate for this error:
        There are two (optional) environment variables controlling the screen
        offset where the balloon-text banner shows up relative to current
        cursor position. Values are given in pixels (default is 0).
        INFOSNAP_SHIFTH  controls the horisontal shift
        INFOSNAP_SHIFTV  controls the vertical shift
        Example:
                We need to move the banner 50 pixels to the left:
                Variable:  INFOSNAP_SHIFTH
                New Value: -50
        Close current design file (i.e. restart InfoSnap).
VERY ADVANCED FINE-TUNING:  (for third-party MDL developers ONLY!)
        If your MDL program is remapping MicroStation's cursor position it will
        surely create undesired side-effects for both InfoSnap and other MDL
        applications as well.
        However InfoSnap gives you at least a way to synchronize herself with
        such brute-force changes:
        Cook book:
        *** on entry to your application (main):
        - mdlSystem_defineCfgVar ( "INFOSNAP_SHIFT_EXTERNAL", "DYNAMIC", CFGVAR_LEVEL_USER );
                *** during the time your app is affecting cursor position:
                - compute the cursor position shift after your changes (x,y offsets in pixels)
                - redefine values of INFOSNAP_SHIFTV and INFOSNAP_SHIFTH as they change:
                - mdlSystem_defineCfgVar ( "INFOSNAP_SHIFTH", newXdelta, CFGVAR_LEVEL_USER );
                - mdlSystem_defineCfgVar ( "INFOSNAP_SHIFTV", newYdelta, CFGVAR_LEVEL_USER );
        *** on exit from your application (unload hook):
        - mdlSystem_deleteCfgVar ( "INFOSNAP_SHIFT_EXTERNAL" );
        InfoSnap will check existence of INFOSNAP_SHIFT_EXTERNAL each time it
        reads its own settings.
        Tip: if any of INFOSNAP_SHIFTV or INFOSNAP_SHIFTH were already defined,
        it would be smart to preserve and restore their initial values as a
        courtessy for the user.
KNOWN PROBLEMS:
        1.
        MicroStation can have (at most) two application windows open.
        InfoSnap won't work when one of those application windows is minimized.
        2.
        InfoSnap does not cooperate very well with EagleEye. Popup can show up
        biased to EagleEye's own popup. I.e. it is affected by cursor-position
        remapping done by EagleEye. It may, or may not be addressed in future.
        For more information see Q&A section below and the section above.
YES-Dept.:
        Yes, it really is the FREE stuff
        Yes, InfoSnap was available for DOS and Alpha NT as well
        Yes, we love to hear your feedback (comp.cad.microstation)
        Yes, it is a taste of MDL-stuff we can create for you (commercially!)
        Yes, there is more to it -- look at InfoGlider companion program!
NO-Dept.:
        No, you don't need to be on SELECT/CSP to get this stuff
        No, MDL source files are not part of this offering. Sorry...
        No, we will not continue support for earlier MicroStation than v7.0
FINAL WORD:
        I am very interested in constructive feedback from you!
        Preferably on USENET (comp.cad.microstation) as I don't have time
        to do custom jobs for free, however if it will be apparent that the
        proposed change (or addition) gain the whole MicroStation community
        (i.e. those who use InfoSnap), I will make it at no charge whatsoever.
        /Chris Zakrewsky
        chris@cadperf.se
        http://www.ustation.se
QUESTIONS? I BET:
Q: I can't see a thing. What is wrong?
        A: If you have other view background color than black, adjust MicroStation's
           Pointer Color (InfoGlider uses the same color): Settings->DesignFile->Color
        Q: The popup banner disappears, sometimes right away, sometimes after
           a while. Can I make it stick?
        A: The banner will disappear when you:
           - press RESET mouse-button
           - run-over the banner with cursor
           - touch the view border with the cursor
           This is by design, in order to uncover geometry beneath the banner
           (frankly, is there the less obtrusive way to do it without a click?)
        Q: The popup banner goes away immediately. What can I do about it?
        A: There is a possible timing-conflict with another application.
           Defining a 'Delay' period (as a fraction of a second) should fix it.
        Q: The popup banner shows up far away from cursor!
        A: See ADVANCED FINE-TUNING section above.
        Q: When I snap to cell components, the popup banner sometimes don't
           show up. MicroStation is highlighting different cell components.
        A: Enable 'Exact elem. target', which enables InfoSnap to see inside
           the cell (or any complex element for that matter).
        Q: *** What is Settings-Snatcher?
        A: When you set InfoSnap balloon-format to 'TABLE', you may pick
           almost anyone of displayed parameters and make it active!
           Just use UP and DOWN arrow keys (or TAB) to select the item inside
           the balloon, and press INSERT key to snatch its setting and make it
           active.
           If you select "Diam=", "Length=" or "Radius=", the value will
           be sent to AccuDraw as the Smart-Locked Distance Delta.
           Note, that you have to have any placement tool active to get this
           working.
           If you select "RF" (Reference File), it will be made the active file.
           If you want go back, press HOME-key.
           There is more:
           If you like to apply ALL settings at once (i.e. make them active),
           just press INSERT key without making the item selection first.
           This one works for all balloon-formats.
        Q: *** What is Message-Snatcher?
        A: When you are using MicroStation standard measure-tools, the numeric
           output  is displayed usually in lower right corner of screen(s).
           If you think that by far more logical place would be in close
           proximity of cursor, activate Message Snatcher and it will display
           those messages near by the cursor.
           In a case you need to recall the last message:
           If you have defined any key as WakeUp-Key, press it.
           (On MicroStation 95 you need to _move_ your cursor slightly while
           key is pressed. This is not necessary on MicroStation SE)
           MicroStation's textual output will pop up again near by the cursor!
           If you have defined mouse button for this purpose, press it when
           no element is highlighted (selected).
        Q: Why Message Snatcher is colliding with Element Info balloon?
        A: You need to define the precedence. Use radio-buttons:
             'Snatcher'-button gives highest priority to Message Snatcher,
             'Elm. Info'-button gives highest priority to InfoSnap Element Info,
             'Both'-button gives the ability to see both.
           Note that 'Both'-setting requires long enough 'Delay' setting.
        Q: Where are the InfoSnap settings stored?
        A: Stand-alone installation: The settings are stored in the application
           itself. It gives a one file less to worry about.
           Network installation: The settings are stored in the INFOSNAP.DAT
           in directory defined by INFOSNAP_SETTINGS environment variable.
        Q: Where is the angular measure taken?
        A: Look carefully close to the mouse cursor (the little one, not the
           large cross-hair snap cursor).
           You'll se a little dot appear. This is the point of measure.
           (It will go away on RESET)
        Q: What is 'User Units = Master/[1.0]' radio-button?
        A: Length (or perimeter) and Area can be reported in Master Units,
           Working Units or User Units (a Master Unit / Divisor ).
           It is handy when geometry was drawn in Imperial units and you want
           InfoSnap to report in Metric units (or vice versa). Just supply a
           suitable divisor to make conversion happen.
        Q: I can see intermitently a '+' prefixes at different places. Why?
        A: The '+' character indicates that immediately following information
           is being temporarily overriden by another setting.
           For example 'CO=3' means element color 3, and '+CO=5' means that
               element color is currently overriden by Level Symbology Attribute
               (in selected view) specifying color 5.  And so forth...
        Q: Is InfoSnap compatible with: ..........  < fill the blanks ;-) >
        A: InfoSnap was tested with MicroStation Foundation products ONLY.
           It has been found to cooperate nicely with a number of third-party
           However, as a freeware it is (non-profit, public domain program),
           there are no plans whatsoever to modify InfoSnap in order to fit
           into any _commercial_ application environment.
           Only other _freeware_ products can be reviewed for compatibility
           issues on the 'free-of-charge' basis.
           This is a matter of our policy: to encourage development of
           non-profit MDL-tools available for general public use (it's you!).
           (If you need _custom_ adjustments anyway - you'll need to pay some
           fee for the effort)
        Q: Which version of InfoSnap match my version of InfoGlider?
        A: The same version. I.e. version numbers must be the same for both
           programs.
        Q: Where is the latest version of InfoSnap available?
        A: At its home:  http://www.ustation.se
LEGAL STUFF:
        MicroStation is a copyrighted trademark of Bentley Systems Inc.
        Other trademarks are acknowledged as property of their respective
        owners.
DISCLAIMER:
        InfoSnap is delivered as-is without any warranties whatsoever.
        You can use it only and solely at your own risk.
end.
GMT+8, 2026-11-22 10:27 , Processed in 0.356367 second(s), 13 queries , Gzip On, File On.
