查看: 1135|回复: 2
[求助] [求助]:取得当前打印机、纸型、打印式样的问题
已领礼包: 3661个
发表于 2005-8-1 09:47:17 | 显示全部楼层 |阅读模式
在秋枫斑竹的batchplot程序中能直接输出当前图形的打印机、纸型、打印式样等
本人怎么也弄不出来,请问各位知道用的是什么方法啊?能不能得到打印机列表呢?
发表于 2005-8-4 13:14:01 | 显示全部楼层
提取与复制
;;;提取当前的打印设置
(defun getclayout ( /  clayout
                    currentlayout currentplotConfiguration ass *mm* plotlayout)
  (setq
    clayout (vla-get-activelayout (vla-get-ActiveDocument (vlax-get-acad-object)))
   (vlax-dump-object clayout T)
  (setq currentlayout (vlax-vla-object->ename clayout)
        currentplotConfiguration (entget currentlayout)
        ass '(2 4 6 7 40 41 42 43 44 45 46 47 48 49 140 141 142 143 147 148 149 70 72 73 74 75)
        plotlayout '()
    (ForEach *mm* ass
      (SetQ  plotlayout  (Cons (assoc *mm* currentplotConfiguration) plotlayout))
  (vl-bb-set 'plotlayout  plotlayout)
;;;复制打印设置
(defun copyclayout ( /  clayout
                    currentlayout currentplotConfiguration plotlayout)
  (setq
        currentplotConfiguration (entget currentlayout))
  (setq plotlayout (vl-bb-ref 'plotlayout ))
  (ForEach *mm* plotlayout
   (setq currentplotConfiguration (subst *mm* (assoc (car *mm*)  currentplotConfiguration) currentplotConfiguration))
  (entmod currentplotConfiguration)
发表于 2005-8-5 20:19:58 | 显示全部楼层
不明白楼主这样做有什么用途?
GMT+8, 2026-11-6 14:29 , Processed in 0.421160 second(s), 36 queries , Gzip On.
