查看: 1979|回复: 20
[公告]:3ds Max 8 揭开面纱
发表于 2005-8-5 16:13:24 | 显示全部楼层 |阅读模式
3ds Max 8.0 令人期待已久的一个版本,于2005.8.1亮相SIGGRAPH 2005。以下我们看看揭开他的神秘面纱!
Autodesk 在SIGGRAPH 2005上发布 3ds Max 8
SAN RAFAEL, Calif.—August 1, 2005—Autodesk, Inc. (NASDAQ: ADSK), today announced Autodesk 3ds Max 8 software, the latest version of its award winning 3D modeling, animation and rendering solution. Designed to provide the most comprehensive and advanced 3D design tools and pipeline workflow, 3ds Max is one of the industry’s most popular solutions for games production, film and video production and design visualization.
价格:
Autodesk 3ds Max 8 software $3,495.
3ds Max 7 到 3ds Max 8 升级版 US $795.
  Autodesk官方网站近日消息:Autodesk公司正式发布3ds max 8,这个专业3D软件的新版本更够帮助游戏开发者、特效艺术家和设计者实现他们的想法。新版本包含很多最新特性,例如高级的角色工具、脚本特性和资源管理工具等。
  3ds max 8强大的最新工具和改进的特性包括:Maxscript Debugger(3ds max脚本调试器),当创建和测试自定义的脚本时可以节省数小时的时间;支持Microsoft DirectX(微软DX驱动程序),使游戏开发者可以在3ds max中为整个游戏直接创建实时的场景shaders;UV Pelt Mapping(UV贴图工具),提供一种高级的方式来基于给定的几何表面的UV坐标快速地生成精确的贴图;Autodesk Vault,一种信息管理方法,已经为数千Autodesk用户使用,还有一种高级的角色开发特性可以简化复杂的搭建和动画。
  3ds max 8将在SIGGRAPH 2005盛会第1700号展厅首次亮相。Autodesk 3ds max 8售价为3495美圆,从3ds max 7升级到3ds max 8需要795美圆。
主要特征:
Create your own reality.
Image courtesy of Funcom
Manage challenging creative projects. Achieve better results in less time. Autodesk® 3ds Max® 8 software delivers flexible, state-of-the-art, productive tools designed for 3D artists in many industries—game development, design visualization, and visual effects.
Expanding an already robust toolset, 3ds Max 8 provides new and enhanced functionality in areas of character development, asset management, and scripting tools.
Animation
View Larger Image
Mix, edit, and transition motions from any 3ds Max animation. Import standard motion capture formats directly to your character rig. Use our new open file format based on XML to write motion files from custom tools and bring them into 3ds Max. Develop photorealistic characters with our improved character development features, cloth and hair simulation tools, award-winning Reactor® physics system, and particle flow.
Modeling
View Larger Image
Extensive, industry-best polygon tools for low- or high-resolution modeling. New, superior polygon modeling tools accelerate the process of adding detail to geometry. Use our fast, unique Edit Poly approach to create everything from simple to complex models.
UV Mapping Tools
View Larger Image
Control unfolding of UV seams with pelt mapping. Create a flat, unified map for texturing your objects by stretching out UVW coordinates. Relax UVs and remove distortion by accurately matching UVs to object geometry. Save tremendous amounts of time and hours of work since seams are exactly where they should be and rarely—if ever—need adjusting afterwards.
Skinning
View Larger Image
Skin anything from low polygon, high-quality game meshes to the most dense of visual effects models. Vertices are now assigned to a bone by default to prevent unwanted stretching and minimize the need to edit envelopes.
Maxscript Scripting Language
View Larger Image
Build solid Maxscripts in less time with our new Maxscript debugger. Add custom functionality into tools with full control over the user interface. Use this object-oriented scripting language to create scripts to extend your 3ds Max toolset, or to optimize your workflow throughout your pipeline.
Customer Showcase
Check out our customers’ amazing work in the 3ds Max showcase.
相关报道:
http://usa.autodesk.com/adsk/ser ... &linkID=5572942
技术手册:
http://images.autodesk.com/adsk/files/3dsMax8_techspec_LTRppc.pdf
发表于 2005-8-7 17:14:06 | 显示全部楼层
哪能下载呀?
发表于 2005-8-8 08:47:19 | 显示全部楼层
先等我能出张像样的图再说吧~~~
发表于 2005-8-8 11:12:12 | 显示全部楼层
发表于 2005-8-13 01:30:30 | 显示全部楼层
8.0也出来呢?这么快啊
已领礼包: 1402个
发表于 2005-9-2 16:19:28 | 显示全部楼层
每个新版本都和其他版本的操作有所不同,旧的max4.0我还没用熟呢,真的跟不上
发表于 2005-9-2 19:18:48 | 显示全部楼层
更新得真快..我才用3DS MAX7不久了...
发表于 2005-9-3 14:22:46 | 显示全部楼层
MAX7。0 中文版才装上去,
发表于 2005-9-4 02:19:01 | 显示全部楼层
好快呀,8.0就出来了,去看一下
发表于 2005-9-4 22:33:18 | 显示全部楼层
有没有DX能告诉我8。0比原来的6。0多了那些功能,速度更快吗?
如果确实很好我就用用试试!
发表于 2005-9-5 17:27:55 | 显示全部楼层
还是等稳定稳定再说吧。软件更新的太快了!*-*3
发表于 2005-9-5 20:53:47 | 显示全部楼层
好用吗?
发表于 2005-9-6 08:36:03 | 显示全部楼层
沙发
发表于 2005-9-7 10:25:15 | 显示全部楼层
有人用过吗?感觉咋样?
发表于 2005-9-10 12:39:57 | 显示全部楼层
谢了!!!
GMT+8, 2026-11-3 01:33 , Processed in 0.555486 second(s), 61 queries , Gzip On.
