查看: 911|回复: 5
[ARX程序]:怎样用ARX程序编写如图所示的"一半"标注?
发表于 2003-3-28 08:14:43 | 显示全部楼层 |阅读模式
怎样用ARX程序编写如图所示的"一半"标注? 谢谢!
发表于 2003-3-28 13:39:16 | 显示全部楼层
Acad::ErrorStatus
setDimsd1(
    Adesk::Boolean sd1);
sd1        Input Boolean for DIMSD1 value
Sets sd1 to be the DIMSD1 value for the dimension as an override.  This function returns Adesk::eOk if successful.  The value of Adesk::kFalse is 0. The value of Adesk::kTrue is 1. See the System Variables section of the AutoCAD Command Reference manual for information on DIMSD1.
Acad::ErrorStatus
setDimsd2(
    Adesk::Boolean sd2);
sd2        Input Boolean for DIMSD2 value
Sets sd2 to be the DIMSD2 value for the dimension as an override.  This function returns Adesk::eOk if successful.  The value of Adesk::kFalse is 0. The value of Adesk::kTrue is 1. See the System Variables section of the AutoCAD Command Reference manual for information on DIMSD2.
 楼主| 发表于 2003-3-28 16:36:10 | 显示全部楼层
chxmhsd : 你好!
   请问 在哪里可以查到上述资料? 谢谢.
发表于 2003-3-29 14:33:26 | 显示全部楼层
CAD的标注是一个匿名块
发表于 2003-4-14 11:45:30 | 显示全部楼层
改如何用 有没有例子看看~
发表于 2003-4-14 16:20:44 | 显示全部楼层
look
GMT+8, 2026-11-4 08:15 , Processed in 0.587932 second(s), 41 queries , Gzip On.
