楼主: HJZ
[分享]:号外:AutoCAD 2006 Service Pack 1发布
发表于 2005-8-25 14:33:35 | 显示全部楼层
我怎么发生了安装错误?
“遇到一个阻碍Service Pack安装的问题。请联系系统管理员。错误代码:3010”
请各位指教!!!!
嗬嗬嗬嗬嗬嗬嗬嗬嗬,虚惊一场,虽然有错误,但我重新启动机器后,第一次运行06需要我重新注册。我就将那个DLL覆盖并使用原来的算号器重新注册成功。
发表于 2005-8-25 16:23:46 | 显示全部楼层
发现一个小问题:升级到SP1后,被干掉的“通讯中心”又回来了。需要再一次干掉它。
发表于 2005-8-25 16:35:06 | 显示全部楼层
各位大老能否介绍一下SP1有什么改进?
发表于 2005-8-25 21:25:58 | 显示全部楼层
最初由 linjs 发布
[B]各位大老能否介绍一下SP1有什么改进? [/B]
尝试过的朋友不妨说说情况啊
*-*b
发表于 2005-8-25 23:27:11 | 显示全部楼层
已成功安装,只是不知有什么用
发表于 2005-8-26 01:05:00 | 显示全部楼层
自定义的加载程序不能再用!
发表于 2005-8-26 02:35:30 | 显示全部楼层
我升级之前搜索了一个以前英文版遗留下来的adlmdll.dll(因为winxp搜索设置成不搜索隐藏的文件),覆盖以后没用。只得尝试重新激活,居然有用,重启acad也没有问题。看来老天爷还是眷顾民工的,只是还没有重启电脑,应该没事吧!
下面是sp1的英文说明,大家凑合着看吧,我也看不懂
Primary Issues Resolved by the Service Pack
Actions That No Longer Cause Fatal Errors
Adding a stretch action to a dynamic block definition in a drawing saved with certain linetypes.
Displaying thumbnail views of DWF files in Windows Explorer.
Opening some types of legacy drawings.
Expanding the Toolbars node in the Customize User Interface dialog box (CUI) after you have migrated custom menus and toolbars from AutoCAD 2005 to AutoCAD 2006.
(AutoCAD only) Editing a multiline using MLEDIT when AutoCAD 2005 and AutoCAD 2006 are installed on the same computer.
Using the Properties palette to set mesh density for a smooth polygon mesh.
Pressing CTRL+A to select objects in certain 3D views.
Running AutoCAD LT on a computer with WindowBlinds software installed.
Problems Reported with the Customer Error Reporting Utility
As a result detailed information from customers who used the Customer Error Reporting Utility, a number of problems were identified and fixed. Updates have been made in the following feature areas.
Command prompt
DesignCenter
Dimensioning
Dragging a drawing
Dynamic blocks
Dynamic Input tooltips
Graphics system
Hatching
Info palette
In-Place Text Editor
Insert
Layer
Layouts
Linetypes
Markup
Migration
Multiline text (Mtext)
Options
ObjectDBXTM
Object snaps
Plot and Publish
Plotting drivers
Properties palette
Selection
Selection previewing
Sheet Set Manager
Startup, Save, and Close
Tables
Text
Tool palettes
Toolbars
General Updates
Other changes included in this service pack include the following updates.
ActiveX API (AutoCAD only)
You can now program the deletion of a button from a toolbar.
Problems that sometimes caused side-by-side incompatibility between AutoCAD 2006 and AutoCAD 2005 have been addressed.
The AddSeparator method now correctly adds a separator to existing pull-down menus.
Calculator
Number format for certain regional settings: QuickCalc calculator variables now persist from one session to another.
The vertical scroll bar in the QuickCalc calculator window is now correctly displayed.
Color
Display properties (such as color, linetype, and lineweight) no longer change unexpectedly when you drag or copy objects.
Data Extraction (AutoCAD only)
Cells for tables created using EATTEXT are now displayed with the appropriate height.
Inability to close the Attribute Extraction dialog box (EATTEXT) under some circumstances has been corrected.
Dimensioning
Correct values are now displayed for each instance of a polar-arrayed dimension.
Dimension associativity is now reliably retained when a drawing is saved. Display errors have also been corrected.
Dynamic Blocks
Inserted dynamic blocks can now be rotated and scaled without losing their dynamic properties.
The drop-down list of available values is now reliably displayed when you click a visability or lookup grip on a dynamic block reference in a drawing.
Dynamic Input
Entering a transparent command (such as 'p) in a Dynamic Input tooltip no longer causes the program to lock up.
When using Dynamic Input, you can now enter the command modifiers tk (for tracking) and tt (to set temporary tracking points for object snap tracking).
Hatching
For legacy drawings, text within solid-filled hatch areas is now correctly displayed.
Key Modifiers
For entries in an edit box in a docked window, the program now distinguishes between temporary override keys (such as SHIFT+E) and capitalized text.
Layers
Saved layer states can now be reliably restored.
Migration
The Customize User Interface dialog box now correctly imports full, partial, and custom menus from previous releases. (This update was released separately as Support Solution TS1052001.)
Display problems resulting from the transfer of legacy MNU or MNS files to AutoCAD 2006-based products have been corrected. This update affects labels in image tile menus and screen menus. (This update was released separately as Support Solution TS1052254.)
Screen menu aliases are now correctly migrated from earlier versions of the product.
Right-click menus are now available when the CUI file is loaded as an enterprise customization file and a partial menu is loaded as the main customization file.
Problems with opening CUI files that have duplicate macro IDs have been corrected.
The object snap menu (SHIFT+right-click) is now available when partial menus are loaded.
You now can delete a custom tool created in the Customize User Interface dialog box without causing an error the next time you try to edit the toolbar or tool palette to which it was added.
Modify
Circles and arcs created on a plane that is not parallel to the world coordinate system (WCS) now move and stretch in the expected direction when they are stretched.
You can now stretch objects in a group individually.
You can now stretch multiple 3D polyline segments.
ObjectARX® and ObjectDBXTM (AutoCAD only)
Performance problems as a result of using a carriage return (\r) with the ads_printf() function have been corrected.
Double-byte languages: The accmGetColorFromACIName() function now behaves as expected when used with multiple-byte color names.
Object Linking and Embedding (OLE)
OLE objects in model space viewports are now clipped correctly when the viewport is resized.
The quality of OLE objects (such as photographs) printed at the highest quality setting has been improved.
Object Snaps
Performance problems using object snaps in certain circumstances have been corrected.
Open
You can now run a script to open another drawing after the first drawing has been closed.
Options
Problems with relative search paths created in the Options dialog box have been corrected.
Plot and Publish
Dot linetypes with line weight are now plotted correctly.
Plot styles for systems with a large number of plot styles are now assigned properly.
The time needed to open the Plot dialog box has improved for customers who have a large number of plot styles.
The name of the layout is now correctly appended to the file name for drawings that are plotted or published to PDF.
Profiles (AutoCAD only)
Profiles are now retained properly when more than one instance of AutoCAD is open.
Tables
Formatting is now preserved for text cut from a Microsoft® Excel spreadsheet and pasted into a table cell.
Text
The spacing between lines of text created with consecutive executions of the TEXT command is now the same as the spacing between lines of text created within a single TEXT command.
Pressing the END key in the Edit Text dialog box no longer causes an error.
Bullets created in the In-Place Text Editor are now displayed correctly in the editor, no matter how many times it is reopened.
Chinese language: CAPS LOCK and SHIFT keys now work properly on Chinese-language keyboards.
Japanese language: Several problems with incorrect display of characters have been corrected.
Double-byte languages: Problems with spacing between double-byte characters have been corrected.
For some Asian input method editors: You now can switch from Asian text entry to English text entry without causing the program to lock up.
Baltic, Turkish, and Greek languages: Problems with the display of SHX fonts have been corrected.
Tool Palette
Using a tool palette no longer causes the incorrect command to run when you press ENTER or right-click to repeat a command.
Xrefs (External References)
External references (xrefs) that have been unloaded are no longer reloaded when you click a balloon notification in the host drawing.
发表于 2005-8-26 07:38:05 | 显示全部楼层
有什么改进么??已经装了的大侠给说说啊
发表于 2005-8-26 10:18:23 | 显示全部楼层
下载中,不过不知道有什么改进
发表于 2005-8-26 11:58:53 | 显示全部楼层
后面安装的测试一下用重新激活的方式行不行,注意先备份那个dll文件,如果你没有ghost的话。
倒要看看是不是自动桌子知道笨笨有ghost就给他点难度
发表于 2005-8-26 12:42:01 | 显示全部楼层
2007不是就快出来了吗?还要有SP1?
发表于 2005-8-26 16:54:03 | 显示全部楼层
最初由 民工 发布
[B]后面安装的测试一下用重新激活的方式行不行,注意先备份那个dll文件,如果你没有ghost的话。
倒要看看是不是自动桌子知道笨笨有ghost就给他点难度 [/B]
你是说sp1用原注册器注册成功?
我的是在提示注册完成后,系统又提示正在验证激活码,随之再次出现“产品激活”界面,如此反复。。。
如果事先没有备份adlmdll.dll而不能注册时,也不必重新安装或Ghost了,在安装盘上可以找到你需要的DLL文件:\Bin\acadFeui\Program Files\Root
发表于 2005-8-26 16:58:49 | 显示全部楼层
我安装时备份成了以前英文版删除后留下的dll,复制过去以后,启动时提示要我激活,我只有用原注册器激活,居然可以了。不知道是不是那个备份也起了作用,可既然起作用为什么还要我激活?
发表于 2005-8-26 17:18:29 | 显示全部楼层
最初由 民工 发布
[B]我安装时备份成了以前英文版删除后留下的dll,复制过去以后,启动时提示要我激活,我只有用原注册器激活,居然可以了。不知道是不是那个备份也起了作用,可既然起作用为什么还要我激活? [/B]
那就是了,这2个文件应该是一样的。
发表于 2005-8-26 18:09:11 | 显示全部楼层
刚下载了,是10M的补丁……
我感觉2006除了移动时偶尔会出现图层颜色不符之外基本上是没有什么大的毛病,所以奇怪补丁为何这么大。
GMT+8, 2026-8-30 10:19 , Processed in 0.700484 second(s), 53 queries , Gzip On.
