查看: 1229|回复: 1
[LISP函数-矩阵]:获取指定UCS的转换矩阵
发表于 2005-9-1 06:35:59 | 显示全部楼层 |阅读模式
  1. ;;
  2. ;;获取指定UCS的转换矩阵
  3. (defun xd-getucsMatrix (ucsname / code10 code11 code12 _z)
  4.   (if (= ucsname "")
  5.     (progn
  6.       (setq code10 (getvar "ucsorg")
  7.             code11 (getvar "ucsxdir")
  8.             code12 (getvar "ucsydir")
  9.       )
  10.     )
  11.     (progn
  12.       (setq code10 (cdr (assoc 10 (tblsearch "ucs" ucsname)))
  13.             code11 (cdr (assoc 11 (tblsearch "ucs" ucsname)))
  14.             code12 (cdr (assoc 12 (tblsearch "ucs" ucsname)))
  15.       )
  16.     )
  17.   )
  18.   (setq _z (xd-vector_crossproduct code11 code12))
  19.   (xd-matrix_setcoordsystem code10 code11 code12 _z)
  20. )
发表于 2005-9-5 12:36:54 | 显示全部楼层
xd-vector_crossproduct 没有定义,可否用GE_VecCrossProduct 来带替
是的。  eachy
GMT+8, 2026-11-22 10:33 , Processed in 0.505457 second(s), 12 queries , Gzip On, File On.
