查看: 934|回复: 3
[讨论]:LISP中如何判断*.SHX是大字体文件
发表于 2005-9-12 20:24:14 | 显示全部楼层 |阅读模式
LISP中如何判断*.SHX是大字体文件.
我是用一个苯办法:
READ-LINE读取SHX文件第一行,如果有"BIGFONT"则为大字体,否则就不是.不知道还有没有别的办法.
已领礼包: 593个
发表于 2005-9-12 21:00:52 | 显示全部楼层
STYLE group codes
Group code
Description
100
Subclass marker (AcDbTextStyleTableRecord)
2
Style name
70
Standard flag values (bit-coded values):
1 = If set, this entry describes a shape
4 = Vertical text
16 = If set, table entry is externally dependent on an xref
32 = If both this bit and bit 16 are set, the externally dependent xref has been successfully resolved
64 = If set, the table entry was referenced by at least one entity in the drawing the last time the drawing was edited. (This flag is for the benefit of AutoCADcommands. It can be ignored by most programs that read DXF files and need not be set by programs that write DXF files)
40
Fixed text height; 0 if not fixed
41
Width factor
50
Oblique angle
71
Text generation flags:
2 = Text is backward (mirrored in X)
4 = Text is upside down (mirrored in Y)
42
Last height used
3
Primary font file name
4
Bigfont file name; blank if none
 楼主| 发表于 2005-9-13 09:58:27 | 显示全部楼层
EA斑竹理解错了,我说的是字体文件,不是文字样式。
已领礼包: 593个
发表于 2005-9-13 12:12:37 | 显示全部楼层
读文件的方法你已经说了
GMT+8, 2026-11-6 15:48 , Processed in 0.480045 second(s), 37 queries , Gzip On.
