查看: 841|回复: 3
[求助]:创建菜单和工具条
发表于 2003-4-7 10:46:55 | 显示全部楼层 |阅读模式
如何使用ARX创建菜单和工具条?
发表于 2003-4-7 19:45:58 | 显示全部楼层
使用AutoCAD COM接口
发表于 2004-6-30 14:16:30 | 显示全部楼层
能不能给各例子
发表于 2004-8-30 20:55:48 | 显示全部楼层
用COM加载的菜单年
void YHLloadmenu()
        // TODO: Implement the command
        try
                IAcadApplication  bsApp( acedGetAcadWinApp()->GetIDispatch( TRUE ) );
                IAcadMenuBar      bsMenuBar( bsApp.GetMenuBar() );
                long              numofMenus;
                numofMenus = bsMenuBar.GetCount();
                IAcadMenuGroups   bsGroups( bsApp.GetMenuGroups() );
                VARIANT index;
                ::VariantInit( &index );
                index.vt = VT_I4;
                index.lVal = 0;
                IAcadMenuGroup   bsGroup( bsGroups.Item( index ) );
                IAcadPopupMenus  bsppMenus( bsGroup.GetMenus() );
                CString  strMenuName = "绘制各段(&K)";
                CString  strName     = "拖拽图块(&Z)";
                VARIANT item;
                ::VariantInit( &item );
                item.vt = VT_BSTR;
                item.bstrVal = strMenuName.AllocSysString();
                IDispatch* pDisp = NULL;
                TRY
                        pDisp = bsppMenus.Item( COleVariant( strMenuName ) );
                        pDisp->AddRef();
                CATCH ( COleDispatchException,e )
                END_CATCH;
                IDispatch* pDisp2 = NULL;
                VARIANT item2;
                ::VariantInit( &item2 );
                item2.vt = VT_BSTR;
                item2.bstrVal = strName.AllocSysString();
                TRY
                        pDisp2 = bsppMenus.Item( COleVariant( strName ) );
                        pDisp2->AddRef();
                END_CATCH;
                // 加载第一个菜单
                if ( NULL == pDisp )
                        IAcadPopupMenu  bsppMenu( bsppMenus.Add( strMenuName ) );
                        index.vt = VT_I4;
                        index.lVal = 0;
                        bsppMenu.AddMenuItem( index,"混合过滤段(&H)","_drawingHHGLD\n" );
                        index.vt = VT_I4;
                        index.lVal = 1;
                        bsppMenu.AddMenuItem( index,"盘管加湿段(&P)","_drawingHHGLD\n" );
                        index.vt = VT_I4;
                        index.lVal = 2;
                        bsppMenu.AddMenuItem( index,"风机段(&F)","_drawingHHGLD\n" );
                        index.vt = VT_I4;
                        index.lVal = 3;
                        bsppMenu.AddMenuItem( index,"中效过滤段(&M)","_drawingHHGLD\n" );
                        index.vt = VT_I4;
                        index.lVal = 4;
                        bsppMenu.AddMenuItem( index,"送风段(&S)","_drawingHHGLD\n" );
                        pDisp = bsppMenu.m_lpDispatch;
                        pDisp->AddRef();
                IAcadPopupMenu  bsppMenu( pDisp );
                if ( !bsppMenu.GetOnMenuBar() )
                        index.vt = VT_I4;
                        index.lVal = numofMenus - 1;
                        bsppMenu.InsertInMenuBar( index );
                else
                        bsppMenus.RemoveMenuFromMenuBar( item );
                pDisp->Release();
                // 加载第二个菜单
                if ( NULL == pDisp2 )
                        IAcadPopupMenu  bsppMenu( bsppMenus.Add( strName ) );
                        index.vt = VT_I4;
                        index.lVal = 0;
                        bsppMenu.AddMenuItem( index,"过滤器主视图(&M)","_TKGLQMAIN\n" );
                        index.vt = VT_I4;
                        index.lVal = 1;
                        bsppMenu.AddMenuItem( index,"过滤器俯视图(&G)","_TKGLQDOWN\n" );
                        index.vt = VT_I4;
                        index.lVal = 2;
                        bsppMenu.AddSeparator( index );
                        index.vt = VT_I4;
                        index.lVal = 3;
                        bsppMenu.AddMenuItem( index,"风机(&F)","_TKFJMAIN\n" );
                        index.vt = VT_I4;
                        index.lVal = 4;
                        bsppMenu.AddMenuItem( index,"照明灯(&D)","_TKZMDMAIN\n" );
                        index.vt = VT_I4;
                        index.lVal = 5;
                        index.vt = VT_I4;
                        index.lVal = 6;
                        bsppMenu.AddMenuItem( index,"检查门(&C)","_TKJCMCIRCLE\n" );
                        index.vt = VT_I4;
                        index.lVal = 7;
                        bsppMenu.AddMenuItem( index,"检查门(&R)","_TKJCMREC\n" );
                        pDisp2 = bsppMenu.m_lpDispatch;
                        pDisp2->AddRef();
                IAcadPopupMenu  bsppMenu2( pDisp2 );
                if ( !bsppMenu2.GetOnMenuBar() )
                        index.vt = VT_I4;
                        bsppMenu2.InsertInMenuBar( index );
                else
                pDisp2->Release();
                ::VariantClear( &index );
                ::VariantClear( &item );
        catch ( COleDispatchException& e )
                e.ReportError();
                e.Delete();
        catch (...)
                // do nothing
GMT+8, 2026-11-6 22:02 , Processed in 0.399727 second(s), 38 queries , Gzip On.
