查看: 849|回复: 1
[求助]:Autoplant 的字体
发表于 2005-9-19 13:39:39 | 显示全部楼层 |阅读模式
我在打开Autoplant PID 文件时,提示如下错误信息:
Replaced missing MicroStation RSC Font (font number = 120)
Replaced missing MicroStation RSC Font (font number = 120) with default MicroStation font STANDARD. Some text may not display correctly. Make sure that the appropriate .rsc files are present in the directory pointed to by the environment variable MS_SYMBRSC.
不知哪里可以找到appropriate .rsc字体,请帮俺找找,谢谢!
 楼主| 发表于 2005-9-23 13:06:36 | 显示全部楼层
没有这个字体,显示和打印出来的夹套管、仪表连线都是乱的。有知道的请帮忙指导一下吧,正急着用呢,先谢谢了。
GMT+8, 2026-11-22 10:35 , Processed in 0.420179 second(s), 12 queries , Gzip On, File On.
