查看: 1039|回复: 4
[求助]:如何读块的插入点坐标?
发表于 2005-9-22 10:32:53 | 显示全部楼层 |阅读模式
如题
发表于 2005-9-22 10:48:57 | 显示全部楼层
AcDbBlockReference 里面有方法。
AcGePoint3d position() const;
This function returns the WCS position point (often referred to as the insertion point) of the block reference.
The position value is the WCS equivalent of the DXF group code 10.
发表于 2005-9-22 15:22:50 | 显示全部楼层
CString xpt[100];
CString ypt[100];
if(acedGetPoint(NULL,"\n请选择点:",pt)==RTNORM)
                xpt[0].Format("%g",pt[X]);
                ypt[0].Format("%g",pt[Y]);
                acutPrintf("\n点坐标为:%s,%s",xpt[0],ypt[0]);
发表于 2005-10-13 16:01:23 | 显示全部楼层
请问楼主现在知道如何得到已知明块在图中的插入点吗?请高手指点下,谢谢!
发表于 2005-10-13 16:07:57 | 显示全部楼层
  1.     AcDbBlockReference *pObject;
  2.    acdbOpenObject(pObject,objId,AcDb::kForRead);
  3.   Scale = pObject->scaleFactors();  比例尺
  4.                         dScale = Scale.sx;
  5.                         dAngle = pObject->rotation(); //璇转交
  6.                         pt = pObject->position();  //插入点
  7.                         strLayer = pObject->layer();
  8.                         colorNum = pObject->colorIndex();
复制代码
GMT+8, 2026-11-7 02:36 , Processed in 0.416775 second(s), 39 queries , Gzip On.
