查看: 847|回复: 0
[ARX函数]:关于文本标注 和 圆圈标注 的问题?
发表于 2005-9-22 19:17:44 | 显示全部楼层 |阅读模式
在指定坐标点进行文本标注:
        AcDbBlockTable *pBlockTablew;
        acdbHostApplicationServices()->workingDatabase()
                ->getSymbolTable(pBlockTablew, AcDb::kForRead);
        AcDbBlockTableRecord *pBlockTableRecorde;
        pBlockTablew->getAt(ACDB_MODEL_SPACE,
                pBlockTableRecorde, AcDb::kForWrite);
        pBlockTablew->close();//关闭块表
                ads_point point;
                int ret;
                acutPrintf("\n请选中权属单位:“%s",CScaption);
                ret = acedGetPoint(NULL,"”标注的中心点:",point);
                ret= acedCommand(RTSTR, "boundary",RTPOINT ,point, RTSTR, "",0) ;
                acutPrintf("\n你选的点坐标为 x = %.3f y = %.3f",point[0],point[1]);
           AcGePoint3d textPosition(point[0], point[1], 0.0);
           AcGePoint3d atextPosition(point[0], point[1], 0.0);
        double textHeight = 10;
        double textWidthFactor = 0.8000;
        double textRotation = 0.0;
        AcDbText *pText=new AcDbText(textPosition, CScaption, AcDbObjectId::kNull ,
textHeight, textRotation);
        pText->setHorizontalMode(AcDb::kTextMid);
        pText->setAlignmentPoint(atextPosition);
        pText->setColorIndex (1);
        AcDbObjectId textId;
        pBlockTableRecorde->appendAcDbEntity(textId, pText); //*
        pBlockTableRecorde->close();
        pText->close();
在指定坐标点进行画圆标注坐标点:
CString xpt[100];
CString ypt[100];
float xco[100];
float yco[100];
        acedGetInt("\n请输入多边形顶点数:",&NodeNumCount);
        if(acedGetPoint(NULL,"\n请选择起始点:",pt)==RTNORM)
                xpt[0].Format("%g",pt[X]);
                ypt[0].Format("%g",pt[Y]);
                acutPrintf("\n起始点坐标为:%s,%s",xpt[0],ypt[0]);
        xco[0]=atof(xpt[0]);
        yco[0]=atof(ypt[0]);
        for(int i=0;i<NodeNumCount;i++)
                if(acedGetPoint(NULL,"\n拾取下一点:",pt)==RTNORM)
                        xpt[i+1].Format("%g",pt[X]);
                        ypt[i+1].Format("%g",pt[Y]);
                        acutPrintf("\n该点坐标为:%s,%s",xpt[i+1],ypt[i+1]);
                xco[i+1]=atof(xpt[i+1]);
                yco[i+1]=atof(ypt[i+1]);
                          pBlockTableRecorde,AcDb::kForWrite);
                AcGeVector3d normal(0.0, 0.0, 1.0);
                AcGePoint3d startPt(xco[n],yco[n],0.0);//定义圈标注的中点
                AcDbCircle *pCirc1 = new AcDbCircle(startPt, normal, num);
                    AcDbObjectId circleId;
                pBlockTableRecorde->appendAcDbEntity(circleId, pCirc1);
                pCirc1->close();
以上两个功能函数均正确!!  以下是两个功能整合过()后的程序,编译无错,但在CAD中会导致-致命错误!估计是定义坐标不一致而导致的
进行圈标注的点---AcGePoint3d startPt(xco[n],yco[n],0.0);
不能做为数字标注的点---AcGePoint3d textPosition(point[0], point[1], 0.0);
希望哪位高手给予指点,我在这里先谢过了!
CString xpt[100];
CString ypt[100];
float xco[100];
float yco[100];
        for(int n=0;n<NodeNumCount;n++)
                AcGePoint3d startPt(xco[n],yco[n],0.0);//定义直线点
                AcDbBlockTable *pBlockTablee;
                    ->getSymbolTable(pBlockTablee, AcDb::kForRead);
                pBlockTablee->getAt(ACDB_MODEL_SPACE, pBlockTableRecorde,AcDb::kForWrite);
                pBlockTablee->close();
   //AcGePoint3d textPosition(xco[n], yco[n], 0.0);//*
   //AcGePoint3d atextPosition(xco[n], yco[n], 0.0);//开始数字标注
            char s1[64];
               sprintf(s1, "%d", n);//强制转换类型
                //AcDb::kTextLeft
                AcDbText *pText=new AcDbText(startPt,s1, AcDbObjectId::kNull , textHeight, textRotation);
                pText->setAlignmentPoint(startPt);
                pText->setColorIndex(1);
                pCirc1->close();
                     pText->close();
GMT+8, 2026-11-6 00:56 , Processed in 0.435794 second(s), 32 queries , Gzip On.
