查看: 1369|回复: 1
[LISP函数]:Windows Scripting Host (FSO/WSH)
发表于 2005-9-24 00:53:58 | 显示全部楼层 |阅读模式
  1. ;; WSH.LSP Copyright 1999 Tony Tanzillo
  2. ;;
  3. ;; WSH.LSP demonstrates how to use the Windows Scripting
  4. ;; Host's FileSystemObject in Visual LISP Applications.
  5. ;;
  6. ;; The FileSystemObject is part of Microsoft's Windows
  7. ;; Scripting Host, which is shipped with Windows 98 and
  8. ;; Internet Explorer. You can also download and install
  9. ;; the Windows Scripting Host on any NT4 or Windows 9x
  10. ;; system by downloading it from Microsoft's web site:
  11. ;;
  12. ;;   [url]http://www.microsoft.com/scripting[/url]
  13. ;;
  14. ;; The FileSystemObject
  15. ;;
  16. ;; The FileSystemObject and its aggregates provide a
  17. ;; well-defined, high-level ActiveX interface to the
  18. ;; file system and its contents.
  19. ;;
  20. ;; Within the FileSystemObject, Drives, Folders, and
  21. ;; Files are all represented by like-named ActiveX
  22. ;; objects (Folder, File, Drive, and so on). Some of
  23. ;; those objects expose a collection property that
  24. ;; provides access to child objects.
  25. ;;
  26. ;; For example, Drive objects have a collection of
  27. ;; Folder objects. Folder objects have a collection of
  28. ;; File objects and SubFolder objects. You can use these
  29. ;; objects and collections to access and process folders
  30. ;; and files in a hierarchial fashion.
  31. ;;
  32. ;; The following is a short synopsys of the properties
  33. ;; and methods of the top-level FileSystemObject. The
  34. ;; aggregate objects within the FileSystemObject (File,
  35. ;; Folder, Drive, and so forth) are not detailed here.
  36. ;; You can get complete information on all child objects
  37. ;; from the Windows Scripting Host documentation.
  38. ;;
  39. ;; Note that the method/property/constant prefix "wsh-"
  40. ;; is VLISP-specific, as defined by the load-scripting
  41. ;; function below.
  42. ;;
  43. ;; Windows Scripting Host FileSystemObject
  44. ;; ---------------------------------------
  45. ;;
  46. ;; Properties:
  47. ;;
  48. ;; (wsh-get-Drives)
  49. ;;
  50. ;; Methods:
  51. ;;
  52. ;; (wsh-BuildPath <Path> <Name>)
  53. ;; (wsh-CopyFile <Source> <Destination> [<Overwrite = :vlax-true>])
  54. ;; (wsh-CopyFolder <Source> <Destination> [<Overwrite = :vlax-true>])
  55. ;; (wsh-CreateFolder <FolderName>)
  56. ;; (wsh-CreateTextFile <FileName> [<Overwrite = :vlax-false> [<Unicode = :vlax-false>]])
  57. ;; (wsh-DeleteFile <FileName> [<Force = :vlax-false>])
  58. ;; (wsh-DeleteFolder <FolderName> [<Force = :vlax-false>])
  59. ;; (wsh-DriveExists <DriveSpec>)
  60. ;; (wsh-FileExists <FileSpec>)
  61. ;; (wsh-FolderExists <FolderSpec>)
  62. ;; (wsh-GetAbsolutePathName <PathSpec>)
  63. ;; (wsh-GetBaseName <Path>)
  64. ;; (wsh-GetDrive <DriveSpec>)
  65. ;; (wsh-GetDriveName <Path>)
  66. ;; (wsh-GetExtensionName <Path>)
  67. ;; (wsh-GetFile <FileSpec>)
  68. ;; (wsh-GetFileName <PathSpec>)
  69. ;; (wsh-GetFolder <FolderSpec>)
  70. ;; (wsh-GetParentFolderName <Path>)
  71. ;; (wsh-GetSpecialFolder <FolderSpec>)
  72. ;; (wsh-GetTempName)
  73. ;; (wsh-MoveFile <Source> <Destination>)
  74. ;; (wsh-MoveFolder <Source> <Destination>)
  75. ;; (wsh-OpenTextFile <FileName> [<IOMode = :wsh-ForReading> [<Create = :vlax-false>
  76. ;;                               [<Format = :wsh-TristateFalse]]])
  77. ;;
  78. ;;
  79. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Global constants
  80. (setq fso:progid "Scripting.FileSystemObject")
  81. (setq fso:prefix "wsh-")
  82. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Utility functions
  83. (defun load-scripting ( / server)
  84.    (if (not wsh-get-drives)
  85.       (progn
  86.          (vl-load-com)
  87.          (setq server (CoGetClassServer fso:progid))
  88.          (if (not server)
  89.             (alert "Error: Windows Scripting Host is not installed")
  90.             (progn
  91.                (vlax-import-type-library
  92.                   :tlb-filename Server
  93.                   :methods-prefix fso:prefix
  94.                   :properties-prefix fso:prefix
  95.                   :constants-prefix (strcat ":" fso:prefix)
  96.                )
  97.             )
  98.          )
  99.       )
  100.    )
  101. )
  102. (defun ProgID->CLSID (ProgID)
  103.    (vl-registry-read
  104.       (strcat "HKEY_CLASSES_ROOT\" progid "\\CLSID")
  105.    )
  106. )
  107. (defun CoGetClassProperty (ProgID property / clsid)
  108.    (if (setq clsid (ProgID->CLSID ProgID))
  109.       (vl-registry-read
  110.          (strcat
  111.             "HKEY_CLASSES_ROOT\\CLSID\"
  112.             clsid
  113.             "\" property
  114.          )
  115.       )
  116.    )
  117. )
  118. (defun CoGetClassServer (progid)
  119.    (CoGetClassProperty progid "InprocServer32")
  120. )
  121. ;; load Windows Scripting Host Type Library
  122. (load-scripting)
  123. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  124. ;;
  125. ;; Windows Scripting Host FileSystemObject Example:
  126. ;;
  127. ;; Function (FindFiles <Folder> <Pattern>)
  128. ;;
  129. ;; This function uses the FileSystemObject to
  130. ;; find all files in a given folder and all
  131. ;; subfolders that match a specified pattern.
  132. ;;
  133. ;; It returns a list of the full filespec of
  134. ;; each file that was found, or nil if no files
  135. ;; were found.
  136. ;;
  137. ;; Note that the pattern argument is a wcmatch-
  138. ;; style wildcard pattern, rather than a DOS
  139. ;; wildcard pattern. Hence, if you want to
  140. ;; include the period extension delimiter in the
  141. ;; pattern, you must prefix it with ` (backquote).
  142. ;;
  143. ;; Finally, this demonstration code is highly-
  144. ;; ineffecient, mainly due to the use of (append)
  145. ;; for constructing the resulting list. If you
  146. ;; are serious about processing large amounts of
  147. ;; files, you may want to consider optimizing it.
  148. ;;
  149. ;; Example (find all LISP files in D:\LISP):
  150. ;;
  151. ;;   (FindFiles "D:\\LISP" "*`.LSP")  ;; Note backquote!!!
  152. (defun FindFiles (FolderSpec Pattern / fso Folder rslt Find:OnSubFolder)
  153.    ;; If the function find-in-folders:onSubFolder is
  154.    ;; defined, it is called and passed each folder
  155.    ;; object that is processed. This function could
  156.    ;; be used to keep a user informed on the progress
  157.    ;; of a long search operation.
  158.
  159.    (defun Find:OnSubFolder (Folder)
  160.       (princ
  161.          (strcat
  162.             "                                                       \r"
  163.             "Searching " (wsh-get-path folder)
  164.          )
  165.       )
  166.    )
  167.    (setq pattern (strcase pattern))
  168.    (setq fso
  169.       (vla-getInterfaceObject
  170.          (vlax-get-acad-object)
  171.          "Scripting.FileSystemObject"
  172.       )
  173.    )
  174.    (setq folder (wsh-GetFolder fso FolderSpec))
  175.    (setq rslt (find-in-folders Folder))
  176.    (vlax-release-object Folder)
  177.    (vlax-release-object fso)
  178.    rslt
  179. )
  180. ;; This recursive function processes each
  181. ;; folder object, and its subfolders.
  182. (defun find-in-folders (Folder / Files SubFolders result)
  183.    ;; Process files in this folder:
  184.
  185.    (setq Files (wsh-get-files Folder))
  186.
  187.    (vlax-for file files
  188.       (if (wcmatch (strcase (wsh-get-name file)) pattern)
  189.          (setq result (cons (wsh-get-path file) result))
  190.       )
  191.       (vlax-release-object file)
  192.    )
  193.    (vlax-release-object files)
  194.
  195.    ;; Process subfolders in this folder (recursive)
  196.
  197.    (setq SubFolders (wsh-get-SubFolders folder))
  198.
  199.    (vlax-for SubFolder SubFolders
  200.       (if Find:OnSubFolder
  201.          (Find:OnSubFolder SubFolder)
  202.       )
  203.       (setq result
  204.          (append result
  205.             (find-in-folders Subfolder)))
  206.       (vlax-release-object subfolder)
  207.    )
  208.    (vlax-release-object SubFolders)
  209.
  210.    result
  211. )
  212. ;;;;;;;;;;;;;;;;;;;;;;;;;;; wsh.lsp ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
发表于 2005-11-4 00:31:32 | 显示全部楼层
我下了,要是加点汉字说明就好了
GMT+8, 2026-11-22 10:31 , Processed in 0.379129 second(s), 12 queries , Gzip On, File On.
