查看: 13969|回复: 59
[推荐]:Revit 8.0 中文版完整下载安装
发表于 2005-9-26 15:07:20 | 显示全部楼层 |阅读模式
Revit 8.0 中文版的主安装文件(RevitBuilding8.0_20050620_2300)下载后,安装时必须在网上同时下载ContentENU、ContentAll、ContentCHS包,十分不方便、而且下载时间很长,对于网速(还要看autodesk的速度及限制)慢的同仁来说,安装过程实在是......。所以,现在我把所有安装文件的下载地址共享出来与大家分享。安装时把RevitBuilding8.0_20050620_2300解压到一个安装目录下,同时建立ContentENU、ContentAll、ContentCHS文件夹,把下载的文件按ContentENU、ContentAll、ContentCHS类别放入,然后开始安装。祝大家好运。(请求加分)
http://revit.downloads.autodesk. ... 0_20050620_2300.exe
http://revit.downloads.autodesk. ... tENU/NAImperial.cab
http://revit.downloads.autodesk. ... NAImperialTempl.cab
http://revit.downloads.autodesk. ... ntentENU/IntMet.cab
http://revit.downloads.autodesk. ... ENU/IntMetTempl.cab
http://revit.downloads.autodesk. ... tentENU/ENUHelp.cab
http://revit.downloads.autodesk. ... ntENU/ENUTutImp.cab
http://revit.downloads.autodesk. ... ntENU/ENUTutMet.cab
http://revit.downloads.autodesk. ... ccuRenderRedist.cab
http://revit.downloads.autodesk. ... ntAll/RPCPeople.cab
http://revit.downloads.autodesk. ... tAll/WebLibrary.cab
http://revit.downloads.autodesk. ... ningFilesCommon.cab
http://revit.downloads.autodesk. ... ngFilesImperial.cab
http://revit.downloads.autodesk. ... ningFilesMetric.cab
http://revit.downloads.autodesk. ... entCHS/ChinaExt.cab
http://revit.downloads.autodesk. ... tCHS/ChinaTempl.cab
http://revit.downloads.autodesk. ... tCHS/ChineseMet.cab
http://revit.downloads.autodesk. ... tentCHS/CHSHelp.cab
http://revit.downloads.autodesk. ... ChineseMetTempl.cab
发表于 2005-10-15 13:52:49 | 显示全部楼层
下載完成....只是分類放好有點搞不清楚
发表于 2005-10-17 10:05:33 | 显示全部楼层
请问这个软件是用来做三维的吗?
发表于 2005-10-17 16:36:38 | 显示全部楼层
不是直接去网站就可以下的嘛,下载还好就是安装的时候很慢!
发表于 2005-10-17 16:58:07 | 显示全部楼层
安装步骤能否说得再详尽些呢?谢谢
压缩包太多,分不清楚,楼主说得那些压缩文件是否都放在那3个文件夹里?如何分类?请详细得说明好吗?谢谢
发表于 2005-10-30 21:15:01 | 显示全部楼层
安装好象还行,就是要求注册,很烦躁
发表于 2005-10-30 23:31:30 | 显示全部楼层
本站有注册机下载的。
发表于 2005-11-18 10:49:38 | 显示全部楼层
楼主应该介绍咋分类?
发表于 2005-11-20 23:07:56 | 显示全部楼层
ContentENU目录包含:NAImperial.cab、NAImperialTempl.cab、IntMet.cab、IntMetTempl.cab、ENUHelp.cab、ENUTutImp.cab、ENUTutMet.cab。
ContentAll目录包含:AccuRenderRedist.cab、RPCPeople.cab、WebLibrary.cab、 TrainingFilesCommon.cab、TrainingFilesImperial.cab、 TrainingFilesMetric.cab。
ContentCHS目录包含:ChinaExt.cab、ChinaTempl.cab、ChineseMet.cab、CHSHelp.cab、ChineseMetTempl.cab。
执行 RevitBuilding8.0_20050620_2300.exe 后要指定已下载保存的目录,打开目录会看到释放了一些文件,此时不要继续安装,直接取消。然后要修改 RevitInstall.ini 文件中的以下语句指向本地盘的目录,修改后就不会再寻找网络安装。
URL=http://revit.downloads.autodesk.com/download/8_0_INT/
存盘退出后执行 RevitInstall.exe 就可以正常安装了。
URL=.
发表于 2005-11-21 20:41:25 | 显示全部楼层
不知道怎么用啊,我再找个高人问问
发表于 2005-11-23 11:47:45 | 显示全部楼层
有用吗?先下载下来试试
发表于 2005-11-25 15:20:30 | 显示全部楼层
谢谢楼主,试试.
发表于 2005-11-26 23:47:35 | 显示全部楼层
请问,安装时授权选择什么?
演示,单机,还是网络?
发表于 2005-11-30 13:42:14 | 显示全部楼层
用以上方法,我安装成功了,解决大问题了.谢谢.
发表于 2005-11-30 14:13:13 | 显示全部楼层
请问楼上的,你安装的时候,选择的是演示,单机,还是网络?
这三个选项,到底选那个?
请教了.
GMT+8, 2026-11-22 09:56 , Processed in 0.294230 second(s), 38 queries , Gzip On, File On.
