查看: 817|回复: 2
[推荐]:autodesk DWG TrueView released
已领礼包: 24个
发表于 2005-10-22 11:34:33 | 显示全部楼层 |阅读模式
Share AutoCAD® drawings easily and accurately among engineers and architects with DWG TrueView™. View and plot DWG and DXF™ files, and then publish them as DWF™ files for quick and easy review and markup in Autodesk® DWF™ Composer. And you’ll always get full drawing fidelity because the DWG viewer is built on the same viewing technology as AutoCAD® 2006 software.
下载地址:
http://download.autodesk.com/esd ... tupDWGTrueView2.exe
约106MB
发表于 2005-10-23 01:52:23 | 显示全部楼层
[iframe h=600 w=100%]http://www.autodesk.com/global/dwfwriter/readme/AutodeskDWFWriter2Readme_CHS.htm[/iframe]
下载:
http://www.autodesk.com/global/d ... DWFwriter2Setup.exe
已领礼包: 24个
 楼主| 发表于 2005-10-28 16:19:27 | 显示全部楼层
今天发现这个  DWG TrueView 原来就是附在 autodesk DWF Composer 2 中的 DWG Viewer 2
看来是 autodesk 现在把他改名了并作为单独推出的 免费软件
现在发布的这个从文件日期和数字签名上看似乎也只有少数文件更新一点而已
楼上贴的 DWF Writter 也是 autodesk DWF Composer 2 其中一部分)
GMT+8, 2026-11-5 04:07 , Processed in 0.408811 second(s), 36 queries , Gzip On.
