查看: 647|回复: 2
[求助]:在 64位操作系统中无法安装 AutoCAD 2006,怎么办?
发表于 2005-10-25 12:27:34 | 显示全部楼层 |阅读模式
AutoCAD 2006在64位操作系统中安装时安装终止,生成“AutoCAD 2006 Setup.log”文件,内容如下:
[10/25/2005 12:22:15] === Installation started on USER by Administrator ===
[10/25/2005 12:22:18] [Info] Windows Installer upgrade is not required
[10/25/2005 12:22:18]   System Version = 3.1.4000.2435
[10/25/2005 12:22:18] Installation skipped: MSI Runtime 3.0
[10/25/2005 12:22:18] Installation skipped: .NET Framework Runtime 1.1 can't be installed on Windows 64-bit
[10/25/2005 12:22:18] Installation aborted
[10/25/2005 12:22:20] === Installation ended ===
请教高手,怎样才能安装呢?
发表于 2005-12-1 20:33:21 | 显示全部楼层
64位系统安装autocad 问题多多,都不知道如何解决,还是32位系统用起来顺手。
发表于 2005-12-1 20:50:31 | 显示全部楼层
换操作系统呗,64位地也好不到哪儿去
GMT+8, 2026-8-30 17:57 , Processed in 0.429008 second(s), 36 queries , Gzip On.
