查看: 1173|回复: 1
[求助]:紧急求助,请帮忙验算一下水池壁强度是否够,谢谢!
发表于 2005-10-27 08:24:51 | 显示全部楼层 |阅读模式
36000*20000*5900的全地上水泥池子,中间用隔墙分成四个廊道,顶部是有间距6000的梁。
如图所示,现在担心36000长的外墙配筋是否足够,会不会出现腹部鼓起来,造成破坏?如何解决?
谢谢啦!
下面是用王新宇编写的矩形水池计算程序的得到计算书:
                                    矩 形 水 池 计 算
     设 计 资 料:
     池顶活荷P1=0(KN/m^2)   覆土厚度ht=0(mm)  池内水位Hw=5900(mm)  容许承载力R=90(KN/m^2)
     水池长度H=36000(mm)       水池宽度B=20000(mm)  池壁高度h0=5900(mm)  底板外伸C1=400(mm)
     底板厚度h1=400(mm)       顶板厚度h2=0(mm)  垫层厚度h3= 100 (mm)  池壁厚度h4=300(mm)
     地基承载力设计值R=90(KPa)
    ________________________________________________________________________________________
     一.地基承载力验算
    ( 1 )底板面积AR1 = (H + 2 * h4 + 2 * C1) * (B + 2 * h4 + 2 * C1)
                     = ( 36  + 2 *  .3  + 2 *  .4 ) * (  20  + 2 *  .3  + 2 *  .4 )
                     =800.3(m^2)
    ( 2 )顶板面积AR2 = (H + 2 * h4) * (B + 2 * h4)
                     = ( 36  + 2 *  .3 ) * (  20  + 2 *  .3 )
                     =753.9(m^2)
    ( 3 )池顶荷载Pg = P1 + ht * 18
                    = 0 +   0  * 18
                    =0    (KN/m^2)
    ( 4 )池壁重量CB = 25 * (H + 2 * h4 + B) * 2 * H0 * h4
                    = 25 * ( 36  + 2 *  .3  +  20 )* 2 *  5.9  *  .3
                    =5009.(KN)
    ( 5 )底板重量DB1 = 25 * AR1 * h1
                     = 25 * 800.3 *  .4
                     =8003 (KN)
    ( 6 )顶板重量DB2 = 25 * AR2 * h2
                     = 25 *753.9 *  0
                     =0    (KN)
    ( 7 )水池全重G = CB + DB1 + DB2 + Fk1
                   =5009.+8003 +0     +0
                   =13012 (KN)
    ( 8 )单位面积水重Pwg = (H * B * Hw * 10) / AR1
                         = ( 36  *  20  *  5.9  * 10) / 800.3
                         =53.08(KN/m^2)
    ( 9 )单位面积垫层重Pd = 23 * h3
                           = 23 *  .1
                           =2.3 (KN/m^2)
    ( 10 )地基反力R0 = Pg + G / AR1 + Pwg + Pd
                     =0     + 13012  / 800.3 + 53.08 + 2.3
                     = 72 (KN/m^2)
            R0 =  72 (KN/m^2) < R = 90(KN /m^2)   地基承载力满足要求!
    二.水池整体抗浮验算
         地下水位在底板以下,不需验算
    三.水池局部抗浮验算
         地下水位在底板以下,不需验算
    四.荷 载 计 算
         (1)池内水压Pw= rw * H0 = 10 *  5.9 = 59 (KN/m^2)
         (2)池外土压Pt:
          池壁顶端Pt2 = [Pg + rt * (ht + h2)] * [Tan(45-φ/2) ^ 2]
                      = [0    + 18 * ( 0  + 0 )] * [Tan(45-30/2) ^ 2]
                      = 0   (KN/m^2)
          池壁底端Pt1 = [Pg + rt * (ht + h2 + H0)] * [Tan(45-φ/2) ^ 2]
                      = [0    + 18  * ( 0  + 0  + 5.9 )] * [Tan(45-30/2) ^ 2]
                      = 35.39(KN/m^2)
          池底荷载qD = Pg + (Fk1 + CB + DB2 ) / AR1
                     = 0    +(0    +5009.+0    ) / 800.3
                     = 6.258(KN/m^2)
    五.内 力 计 算
    (H边)池壁内力计算
     H / H0 =36000 /5900=6.1
     由于  H / H0 > 3
     故按竖向单向板(挡土墙)计算池壁内力
          1.池外(土、水)压力作用下池壁内力
            Pt0 = Pt1 - Pt2=35.39 -0   = 35.39 (KN/m^2)
           底 端 弯 矩Mn2 = -(Pt1 + 2 * Pt2) * (H0 ^ 2) / 6
                          = -(35.39 + 2 * 0   ) * ( 5.9  ^ 2) / 6
                          = -205(KN-m)
          角隅最大弯矩Mj1 = -0.426 * Pt1 * H0 ^ 2
                          = -0.426 *35.39 *  5.9  ^ 2
                          = -524(KN-m)
          2.池内水压力作用下池壁内力
           底 端 弯 矩Mw2 = -(Pw * H0 ^ 2) / 6
                          = -( 59  *  5.9  ^ 2) / 6
                          = -342(KN-m)
          角隅最大弯矩Mj2 = -0.104 * Pw * H0 ^ 2
                          = -0.104 * 59  *  5.9  ^ 2
                          = -213(KN-m)
     由于B边池壁高度与H边相同,故计算从略,内力计算结果参见H边池壁计算。
                         【计算结束时间:2005-10-27 13:15:35 】
发表于 2005-10-29 22:41:09 | 显示全部楼层
你计算模型与所配的钢筋有问题。这么高的水池用300厚的悬壁板来计算,其钢筋是没办法配上的!一般这样大的水池,是在池壁上设置扶壁柱,顶上用拉梁连接形成框架,将池壁分格,按双向板计算。至于板的配筋,应按抗裂要求配置。请在本版后一页找本人发的厚板配筋表,可能对你有帮助。
GMT+8, 2026-11-23 17:14 , Processed in 0.396880 second(s), 12 queries , Gzip On, File On.
