查看: 951|回复: 8
[求助]:紧急求助,请帮忙验算一下水池壁强度是否够,谢谢。
已领礼包: 6个
发表于 2005-10-27 17:43:03 | 显示全部楼层 |阅读模式
36000*20000*5900的全地上水泥池子,中间用隔墙分成四个廊道,顶部是有间距6000的梁。
如图所示,现在担心36000长的外墙配筋是否足够,会不会出现腹部鼓起来,造成破坏?如何解决?
谢谢啦!
下面是用王新宇编写的矩形水池计算程序的得到计算书:
矩 形 水 池 计 算
设 计 资 料:
池顶活荷P1=0(KN/m^2) 覆土厚度ht=0(mm) 池内水位Hw=5900(mm) 容许承载力R=90(KN/m^2)
水池长度H=36000(mm) 水池宽度B=20000(mm) 池壁高度h0=5900(mm) 底板外伸C1=400(mm)
底板厚度h1=400(mm) 顶板厚度h2=0(mm) 垫层厚度h3= 100 (mm) 池壁厚度h4=300(mm)
地基承载力设计值R=90(KPa)
________________________________________________________________________________________
一.地基承载力验算
( 1 )底板面积AR1 = (H + 2 * h4 + 2 * C1) * (B + 2 * h4 + 2 * C1)
= ( 36 + 2 * .3 + 2 * .4 ) * ( 20 + 2 * .3 + 2 * .4 )
=800.3(m^2)
( 2 )顶板面积AR2 = (H + 2 * h4) * (B + 2 * h4)
= ( 36 + 2 * .3 ) * ( 20 + 2 * .3 )
=753.9(m^2)
( 3 )池顶荷载Pg = P1 + ht * 18
= 0 + 0 * 18
=0 (KN/m^2)
( 4 )池壁重量CB = 25 * (H + 2 * h4 + B) * 2 * H0 * h4
= 25 * ( 36 + 2 * .3 + 20 )* 2 * 5.9 * .3
=5009.(KN)
( 5 )底板重量DB1 = 25 * AR1 * h1
= 25 * 800.3 * .4
=8003 (KN)
( 6 )顶板重量DB2 = 25 * AR2 * h2
= 25 *753.9 * 0
=0 (KN)
( 7 )水池全重G = CB + DB1 + DB2 + Fk1
=5009.+8003 +0 +0
=13012 (KN)
( 8 )单位面积水重Pwg = (H * B * Hw * 10) / AR1
= ( 36 * 20 * 5.9 * 10) / 800.3
=53.08(KN/m^2)
( 9 )单位面积垫层重Pd = 23 * h3
= 23 * .1
=2.3 (KN/m^2)
( 10 )地基反力R0 = Pg + G / AR1 + Pwg + Pd
=0 + 13012 / 800.3 + 53.08 + 2.3
= 72 (KN/m^2)
R0 = 72 (KN/m^2) < R = 90(KN /m^2) 地基承载力满足要求!
二.水池整体抗浮验算
地下水位在底板以下,不需验算
三.水池局部抗浮验算
地下水位在底板以下,不需验算
四.荷 载 计 算
(1)池内水压Pw= rw * H0 = 10 * 5.9 = 59 (KN/m^2)
(2)池外土压Pt:
池壁顶端Pt2 = [Pg + rt * (ht + h2)] * [Tan(45-φ/2) ^ 2]
= [0 + 18 * ( 0 + 0 )] * [Tan(45-30/2) ^ 2]
= 0 (KN/m^2)
池壁底端Pt1 = [Pg + rt * (ht + h2 + H0)] * [Tan(45-φ/2) ^ 2]
= [0 + 18 * ( 0 + 0 + 5.9 )] * [Tan(45-30/2) ^ 2]
= 35.39(KN/m^2)
池底荷载qD = Pg + (Fk1 + CB + DB2 ) / AR1
= 0 +(0 +5009.+0 ) / 800.3
= 6.258(KN/m^2)
五.内 力 计 算
(H边)池壁内力计算
H / H0 =36000 /5900=6.1
由于 H / H0 > 3
故按竖向单向板(挡土墙)计算池壁内力
1.池外(土、水)压力作用下池壁内力
Pt0 = Pt1 - Pt2=35.39 -0 = 35.39 (KN/m^2)
底 端 弯 矩Mn2 = -(Pt1 + 2 * Pt2) * (H0 ^ 2) / 6
= -(35.39 + 2 * 0 ) * ( 5.9 ^ 2) / 6
= -205(KN-m)
角隅最大弯矩Mj1 = -0.426 * Pt1 * H0 ^ 2
= -0.426 *35.39 * 5.9 ^ 2
= -524(KN-m)
2.池内水压力作用下池壁内力
底 端 弯 矩Mw2 = -(Pw * H0 ^ 2) / 6
= -( 59 * 5.9 ^ 2) / 6
= -342(KN-m)
角隅最大弯矩Mj2 = -0.104 * Pw * H0 ^ 2
= -0.104 * 59 * 5.9 ^ 2
= -213(KN-m)
由于B边池壁高度与H边相同,故计算从略,内力计算结果参见H边池壁计算。
【计算结束时间:2005-10-27 13:15:35 】
发表于 2005-10-27 20:47:32 | 显示全部楼层
内力计算如果正确,可以取合力弯矩,计算配筋:
取最大弯矩524,计算可以得到: As好像不够啊
取324 计算,As也要4000多啊,不知道怎么差这么多,请前辈们指点
估计要+强混凝土强度,大于C30
按照342-205=119 计算,采用C30As=1600  这个就差不多了
都是采用2级钢计算
已领礼包: 6个
 楼主| 发表于 2005-10-27 22:01:48 | 显示全部楼层
是要取合力来计算吗?
池外没有土,为什么会有池外压力?
究竟此时外墙受到的弯矩是多少?
已领礼包: 6个
 楼主| 发表于 2005-10-27 22:15:58 | 显示全部楼层
以下是别人用世纪旗云水池计算出来的计算书。
大家帮我看看,提些建议?谢谢
发表于 2005-10-28 10:04:31 | 显示全部楼层
把纵筋放外面吧
已领礼包: 6个
 楼主| 发表于 2005-10-28 10:25:02 | 显示全部楼层
谢谢。
实际上竖直筋是在外面的。
发表于 2005-10-29 11:32:31 | 显示全部楼层
楼主你好!可以把王新宇编写的矩形水池计算程序,发一个我学习一下吗?谢谢!
可以的话发到这个邮箱:sleepchenyu@163.com
已领礼包: 6个
 楼主| 发表于 2005-10-30 10:53:15 | 显示全部楼层
网上很多的,是免费的软件。
到这里下吧:
http://co.163.com/forum/content/234_74605_1.htm
发表于 2006-4-16 02:07:58 | 显示全部楼层
感觉都不是太好用。
GMT+8, 2026-11-3 19:23 , Processed in 0.772554 second(s), 49 queries , Gzip On.
