查看: 807|回复: 2
[其他]:怎样修改坐标标注
发表于 2005-11-9 10:25:15 | 显示全部楼层 |阅读模式
对于我来,很好,谢谢
发表于 2005-11-9 11:36:45 | 显示全部楼层
你要修改坐标标注 什么?
我也想知道怎么修改坐标标注的原点,可要还没找到办法
各位大侠快来帮帮忙啊
发表于 2005-11-11 10:06:17 | 显示全部楼层
我的坐标标注程序:(VB写的,刚学二次开发)
Private Sub 坐标注记_Click()
    Dim Pnt(0 To 2) As Double
    Dim point1 As Variant
    Dim point2 As Variant
    Dim LineObj1 As AcadLine
    Dim LineObj2 As AcadLine
    Dim XTxtObj As AcadText
    Dim YTxtObj As AcadText
    Dim XInsertPnt(0 To 2) As Double
    Dim YInsertPnt(0 To 2) As Double
    Dim XCoord As String
    Dim YCoord As String
    Dim deltax As Double
    point1 = acaddoc.Utility.GetPoint(, "指定注记点: ")
    point2 = acaddoc.Utility.GetPoint(point1, "指定注记位置: ")
    If point2(0) > point1(0) Then
        deltax = -7
        XInsertPnt(0) = point2(0): XInsertPnt(1) = point2(1) + 0.6: XInsertPnt(2) = point2(2)
        YInsertPnt(0) = point2(0): YInsertPnt(1) = point2(1) - 1.5: YInsertPnt(2) = point2(2)
    Else
        deltax = 7
        XInsertPnt(0) = point2(0) - deltax: XInsertPnt(1) = point2(1) + 0.5: XInsertPnt(2) = point2(2)
        YInsertPnt(0) = point2(0) - deltax: YInsertPnt(1) = point2(1) - 1.2: YInsertPnt(2) = point2(2)
    End If
    Pnt(0) = point2(0) - deltax: Pnt(1) = point2(1): Pnt(2) = point2(2)
    Set LineObj1 = acaddoc.ModelSpace.AddLine(point1, point2)
    Set LineObj2 = acaddoc.ModelSpace.AddLine(point2, Pnt)
    LineObj1.Layer = "ZJ"
    XCoord = point1(1): YCoord = point1(0)
    XCoord = Str(QUWEI(Val(XCoord), 3))
    YCoord = Str(QUWEI(Val(YCoord), 3))
    Set XTxtObj = acaddoc.ModelSpace.AddText(XCoord, XInsertPnt, 1)
    Set YTxtObj = acaddoc.ModelSpace.AddText(YCoord, YInsertPnt, 1)
End Sub
Public Function QUWEI(X As Double, Y As Integer) As Double '数据四舍五入取位函数
     'X为需要四舍五入的字符串数据,Y为小数点后保留的位数
    Dim p As String
    Dim g As Integer
    Dim dotback As String '小数点后数据
    Dim dotbefore As String '小数点前数据
    Dim n As String
    Dim k As String
    p = Str(X)
    p = RTrim(LTrim(p))
    g = InStr(1, p, ".")
    dotbefore = Left(p, g - 1)
    dotback = Right$(p, Len(p) - g)
    dotback = Left(dotback, Y + 1)
    n = Right(dotback, 1)
    dotback = Left(dotback, Y)
    k = Right(dotback, 1)
    dotback = Left(dotback, Y - 1)
    If Val(n) >= 5 Then
        k = Str(Val(k) + 1)
    End If
    dotback = dotback + k
    QUWEI = Val(dotbefore + "." + dotback)
End Function
GMT+8, 2026-11-3 06:08 , Processed in 0.441171 second(s), 36 queries , Gzip On.
