查看: 1208|回复: 2
[下载]:最新版Acmecad Converter5.73和cadsee4.8注册下载!
发表于 2005-11-11 13:59:59 | 显示全部楼层 |阅读模式
支持dwg文件转换成各个版本及各种图片
更新历史:
(意思很简单,没有翻译)
Ver5.73
fixed bug when export into vector format.
Ver5.72
fixed crashbug when save into jpeg format.
Ver 5.7
Supports eTransmit command like AutoCAD. you can package a set of files for Internet transmission.
Supports batch recover drawing files. When you have many damaged drawing files, this function will help you.
Some bugs fixed.
Ver 5.6
support WindowXP themes style.
Ver 5.54
Fix dwg/dxf/dwf conversion bug
Ver 5.53
Fix dwg/dxf conversion bug
Can set PDF page size directly
Ver 5.52
Some mini bugs fixed
Ver 5.51
Fix a error when CADConverter export all layouts to other vector file
Ver 5.5
Can pick a window for exporting to other vector format files
Some bugs fixed.
下载地址:http://www.freefirestudio.com/download/acmecad.exe
最新版acmecadsee4.8
像acdsee一样浏览dwg文件
更新历史
Ver 4.8
+ Supports PSD format file now
+ Supports cut to clipboard function now
+ Can rename the file name directly
+ Can create new folder now
- Some bugs fixed
Ver 4.73
- fixed crashbug when loading preview from some dwg.
Ver 4.72
+ added 0 width thumbnail style.
- some bug fixed.
Ver 4.71
+ Improved performance and stableness
Ver 4.7
- Trial bug fixed.
Ver 4.6
- Trial bug fixed.
下载地址:http://www.freefirestudio.com/download/acadsee.exe
汉化可以用以前汉化版本的Chinese.lan文件copy到安装目录下
有需注册机的见下
Acmecad Converter5.73和cadsee4.8注册机(两个)
已领礼包: 69个
发表于 2005-11-11 14:24:29 | 显示全部楼层
谢谢楼主!好东东!下载试试!!!
发表于 2005-11-11 19:50:44 | 显示全部楼层
找了好久谢谢楼主
GMT+8, 2026-11-5 03:48 , Processed in 0.698842 second(s), 37 queries , Gzip On.
