查看: 3189|回复: 10
[求助]:V-Ray for SketchUp 1.0.0大家能找到这个软件吗!?
发表于 2005-11-11 21:32:36 | 显示全部楼层 |阅读模式
BALTIMORE, MD - November 09, 2005 - ASGvis announces that VRay for SketchUp 1.0.0 is in the early stages of development as native plug-in for SketchUp 5.
At SIGGRAPH 2005 ASGvis, LLC teamed up with the Chaos Group to give a preview of it's SketchUp to VRay plugin that bridges SketchUp from @Last Software to the standalone version of the V-Ray rendering system. V-Ray will now be available as a plugin native to SketchUp. More prodcut details can be found at www.asgivs.com/VforS.html. SketchUp users in all fields will soon have access to a V-Ray for SketchUp beta testing program. An official date for V-Ray for SketchUp beta testing program and final release of the plugin will be announced in the coming weeks.
The retail price for Vray for SketchUp will be $799.00 USD for commercial version. Educational and Academic versions of the plug-in will retail for $250.00 USD.
About ASGvis, LLC
ASGvis is a computre graphics service provider and software developer of plug-ins, exporters, scripts, and custom 3d graphics applications. The company is located in downtown Baltimore, Maryland USA.
V-Ray and the V-Ray logo are trademarks or registered trademarks of Chaos Software Ltd.SketchUp are either registered trademarks or trademarks of @Last Software, Inc in the USA and/or other countries. All other brand names, product names, or trademarks belong to their respective holders.
发表于 2005-11-12 02:46:58 | 显示全部楼层
楼主这段消息的来源不知是否可靠,就我所知SU的插件接口还未能如此开放更说不上强大,单凭RUBY脚本实现的功能,不可能整合到SU界面中,最多只能调用其它程序执行操作,其实是也就省了用户“导出”再“导入”而已,况且$799.00 USD 的价格足够买2套SU了。如果天幸这个消息是真的那真是“天幸”了,Oday组织不会坐视不理的。
发表于 2005-11-12 07:15:30 | 显示全部楼层
如果是真的就好了,那3D就毫无优势可言了,ARTLANTIS也毫无优势了^_^,因为我喜欢V-RAY
发表于 2005-12-5 15:26:02 | 显示全部楼层
SKETCH 是用来推敲体量的,作这么真实就失去了他的特色了
发表于 2005-12-6 08:36:59 | 显示全部楼层
http://www.asgvis.com/#
发表于 2005-12-6 10:31:15 | 显示全部楼层
但愿是真的,有希望才有动力
发表于 2005-12-7 00:38:11 | 显示全部楼层
可惜没有提供下载。
发表于 2005-12-7 11:20:24 | 显示全部楼层
有是有,就是不知道为什么没有下载
真实raytraced 反射和折射
光滑反射和折射
区域阴影(软的阴影) 。包括箱子和球形放射器。
间接照明(全球性照明, 全球性照明设备) 。不同的方法 包括直接计算(强力), 并且irradiance 映射。
行动迷离。包括 Quasi-Monte Carlo 采样方法
深度领域照相机作用。
Antialiasing 。包括固定的, 简单2 水平和能适应的方 法。
腐蚀剂
优选材料为快速地回报
充分 地multithreaded raytracing 的引擎
可再用 irradiance 地图(保存和装载支持) 。增加采样为飞行通过动画。
光子映射
可再用刻薄和全球性光子地图(保存 和装载支持) 。
真实的HDRI 支持。包括支持* hdr 图像装货与 适当的纹理配合处置为立方体和有角地图。映射你的图像直接地没 有畸变或庄稼。
当地区域光为完全正确照明。
G 缓冲剂(RGBA, material/object 身份证, Z 缓冲剂, 速度等。)
行动迷离与分析采样
分布 的回报为运用所有你的演播室计算机。根据只TCP/IP 实现一个人连 接经由网际网络。
不同的照相机型号: 鱼眼睛, 球状, 圆柱形和立方体照相机
位移映射。包括一种快速第2 种bitmap 算法并且真实3D 位移映射。
支持NURBS 几何
Vray 轻物质
预先 设定材料(金属, 塑料, 等。)
G 缓冲剂根据 antialiasing 。
http://www.asgvis.com/StoV.html
发表于 2007-2-9 12:30:15 | 显示全部楼层
thank...good information....
发表于 2007-2-9 16:14:23 | 显示全部楼层
谁规定这个软件只能用来推敲体量?个人用法不同,何必守得那么死。
  强烈期待1.0.0的出现,最好有破解,有中文。
发表于 2007-7-5 11:41:44 | 显示全部楼层
有倒是有,可惜只能试用!
GMT+8, 2026-11-3 01:30 , Processed in 0.544753 second(s), 50 queries , Gzip On.
