查看: 879|回复: 0
[分享]:一个在画板过程中表示板范围的工具
发表于 2005-11-16 21:54:08 | 显示全部楼层 |阅读模式
在画板过程中经常要表示板范围!
源代码如下:
(defun c:bf( / p0 p1 p2)
  (while
     (setvar "dimtxt" 0.001)
     (setvar "dimgap" 0)
     (command "dim" "ali"
                     "nea" (setq p1 (getpoint"\n点取第一边界"))
                     "per" (setq p2 (getpoint p1 "\n点取第二边界"))
                     pause "" "exit"
          (while (setq p0 (getpoint "\n点取钢筋"))
                    (command "circle" "int" p0 75)
     ;;(OOPS_VAR)(INDIM)
GMT+8, 2026-11-2 22:15 , Processed in 0.401379 second(s), 31 queries , Gzip On.
