查看: 1196|回复: 6
[求助] [求助]:编程时如何过滤掉其他实体,只选择性地删除文字或标注?
发表于 2005-11-19 14:24:45 | 显示全部楼层 |阅读模式
如题
已领礼包: 9347个
发表于 2005-11-19 15:36:45 | 显示全部楼层
(command "_.Erase" (ssget "X" '((0 . "*TEXT,DIMENSION"))))
 楼主| 发表于 2005-11-19 20:21:46 | 显示全部楼层
我是指运行命令后,在选择时不会选择到其他实体
发表于 2005-11-19 20:41:23 | 显示全部楼层
  1. [FONT=courier new](command "_.Erase" (ssget '((0 . "*TEXT,DIMENSION"))))[/FONT]
 楼主| 发表于 2005-11-20 09:18:05 | 显示全部楼层
为何选择之后要两次回车才能结束命令呢?
  2. (defun c:et ()
  3. (command "_.Erase" (ssget '((0 . "*TEXT"))))
  4. )
  5.   [/FONT]
已领礼包: 9347个
发表于 2005-11-20 09:41:18 | 显示全部楼层
Command: (command "_.Erase" (ssget '((0 . "*TEXT"))) "" "")
_.Erase
Select objects: Specify opposite corner: 2 found
Select objects: Specify opposite corner: 2 found, 4 total
Select objects: Specify opposite corner: 2 found, 6 total
Select objects:
Select objects:   6 found
Select objects:
 楼主| 发表于 2005-11-20 10:58:38 | 显示全部楼层
终于搞定,选择性删除文字
  1. (defun c:et ()
  2. (if (setq x (ssget '((0 . "TEXT"))))
  3.     (command "._erase" x "")
  4. )
  5. )
GMT+8, 2026-11-6 17:52 , Processed in 0.625522 second(s), 44 queries , Gzip On.
