查看: 1208|回复: 3
[求助] [求助]:请问大侠,如何获得LWPOLYLINE线的端点坐标?
发表于 2005-11-23 16:37:22 | 显示全部楼层 |阅读模式
已领礼包: 9284个
发表于 2005-11-23 17:16:29 | 显示全部楼层
Tony Tanzillo
Jan 17 2004, 5:38 pm   show options
Newsgroups: autodesk.autocad.customization
From: "Tony Tanzillo" <tony.tanzillo at caddzone dot com> - Find messages by this author
Date: Sat, 17 Jan 2004 04:19:20 -0500
Local: Sat, Jan 17 2004 5:19 pm
Subject: Re: List of points?
Reply to Author | Forward | Print | Individual Message | Show original | Report Abuse
I can't say this is 'cool' but it handles both
2d and 3d coordinates (by passing the number of
dimensions in the second arg).
I've been using (and posting it here) since around
the time that A2K was released.
;; Convert a flat list of 2d or 3d points as
;; returned by various properties of ActiveX
;; objects, to a list of point lists. The first
;; argument is a simple list of doubles in the
;; form (x1 y1 [z1] x2 y2 [z2]...). The second
;; argument is the number of dimensions (which
;; must be either 2 or 3).
(defun Coordinates->List (vlist dims / rslt)
   (if (eq dims 2)
      (while
         (setq rslt
            (cons
               (list
                  (car vlist)
                  (cadr vlist)
               rslt
            vlist (cddr vlist)
      (while
         (setq rslt
            (cons
               (list
                  (car vlist)
                  (cadr vlist)
                  (caddr vlist)
               rslt
            vlist (cdddr vlist)
   (reverse rslt)
(Coordinates->List
  (vlax-safearray->list
    (vlax-variant-value
      (vlax-get-property
        (vlax-ename->vla-object ee)    ; ee == LWPOLYLINE
        'Coordinates
  2
发表于 2005-11-23 22:08:12 | 显示全部楼层
  1. [FONT=courier new](vlax-curve-getstartPoint (car(entsel"\n选择LWPOLYLINE线 : ")))[/FONT]
复制代码
发表于 2005-11-23 22:11:09 | 显示全部楼层
记下了!
GMT+8, 2026-10-17 04:10 , Processed in 0.401435 second(s), 38 queries , Gzip On.
