查看: 890|回复: 0
[分享]:提取pline坐标时注意坐标系变换
发表于 2005-11-24 20:59:28 | 显示全部楼层 |阅读模式
提取pline坐标时应注意lwpline的坐标系变换问题
lwpline的coordinate属性中只有x,y两个坐标值
需要从Elevation 属性中提取高度信息,从Normal 属性中提取法向信息,然后使用坐标变换函数TranslateCoordinates 将lwpline的顶点坐标从ocs换到ucs
这是cad帮助文件中的说明:
To translate a point on a Polyline or LightWeightPolyline object from OCS to WCS:
1. Get the X and Y coordinates of the OCS point from the Coordinate or Coordinates property.
2. Get the Z coordinate of the OCS point from the Elevation property.
3. Get the normal for the polyline from the Normal property.
4. Call TranslateCoordinates using the X, Y, Z coordinates and the Normal.
这是CadAssis中提取pline节点坐标的关键代码:
            For nn = 0 To CountVertex                           '将AddPolyline坐标转化为x,y,z习惯数组格式
                Dim pntVertexTemp() As Double
                pntVertexTemp = returnObj.Coordinate(nn)
                If returnObj.ObjectName = "AcDbPolyline" Then       '二维多义线
                    pntVertexTemp = ArrayConvert2to3(returnObj.Coordinate(nn))  '二维坐标转三维
                    pntVertexTemp(2) = returnObj.Elevation
                    pointUCS = acadUtil.TranslateCoordinates(pntVertexTemp, acOCS, acUCS, False, returnObj.Normal)    'Wcs->Ucs
                Else
                    pointUCS = acadUtil.TranslateCoordinates(pntVertexTemp, acWorld, acUCS, False)   'Wcs->Ucs
                End If
                plinePnt(nn, 0) = pointUCS(0): fptsPlineVertexUcs(nn * 3 + 0) = pointUCS(0)
                plinePnt(nn, 1) = pointUCS(1): fptsPlineVertexUcs(nn * 3 + 1) = pointUCS(1)
                plinePnt(nn, 2) = pointUCS(2): fptsPlineVertexUcs(nn * 3 + 2) = pointUCS(2)
            Next nn
GMT+8, 2026-11-3 19:12 , Processed in 0.693741 second(s), 32 queries , Gzip On.
