查看: 846|回复: 2
[求助]:哪里有MDI的例子啊?
发表于 2005-12-18 10:14:11 | 显示全部楼层 |阅读模式
哪里有MDI的例子啊?
发表于 2005-12-18 11:06:45 | 显示全部楼层
Docman sample Readme.txt
(C) Copyright 1998 by Autodesk, Inc.
This sample demonstrates some aspects of the MDI document management API.
The following commands are available
LISTDOCS    - lists all open documents.
WATCHDOCS   - starts/stops watching document activity. When on Docman prints
              messages to the command line about various MDI operations,
              such as activation, creation, and locking.
SEND        - exercises switching between documents and sending commands.
TOGGLE      - exercises toggling activation on and off.
NEWDOC      - exercises creating a new document in MDI using the standard user interface.
OPENDOC     - exercises opening a document in MDI using the standard user interfacec.
CLOSEDOC    - exercises closing a document in MDI using the standard user interface.
CMD         - routine to exercise ads_command.
ACTIVATE    - utility to have the user choose an open document to be activated programmatically.
APPCONTEXT  - requests a routine to be executed via the application context.
OPENSYNCDOC - requests an OPEN to be executed via the application context.
NEWSYNDOC   - requests a NEW to be executed via the application context.
Please see the Remarks section for each command handle for more details on these commands.
TESTDLG - displays a modeless dialog with several UI elements that perform MDI API calls.
          Below is a description of the UI elements.
这个例子符合你的要求么?
ObjectARX 2004\samples\editor\docman
 楼主| 发表于 2005-12-18 18:51:51 | 显示全部楼层
这个例子我看过了,有没有其他的啊?
GMT+8, 2026-11-5 22:03 , Processed in 0.393857 second(s), 36 queries , Gzip On.
