查看: 708|回复: 3
[ARX程序]:急求如何创建新图层?
发表于 2005-12-18 13:52:14 | 显示全部楼层 |阅读模式
急求如何创建新图层?
发表于 2005-12-18 16:12:27 | 显示全部楼层
AcDbLayerTableRecord* pNewLayer = new AcDbLayerTableRecord;
//access the AcDbLayerTable pointer
pLayerTable->add(id,pNewLayer);
pNewLayer->close();
By the way, you'd better find answers in Arx help file before ask such question like this.
发表于 2005-12-18 18:54:25 | 显示全部楼层
void createNewLayer(char* lyrname)
        // We need to check if the layer name exists
        // If the layer name exists, apply the color
        // linetype id and whither to make it current
        // or not. In order to be current it cannot be
        // frozen, so we need to check for this also.
        // If the layer name does not exist we just create
        // a new layer with the properties contained in the arguments
        AcDbLayerTable *pLyrTable;
        AcDbLayerTableRecord *pLyrTblRecord;
        AcDbObjectId recId;
        AcDbDatabase *pCurDb = NULL;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        pCurDb->getLayerTable(pLyrTable, AcDb::kForRead);
        // Check to see if the layer name exists
        if(pLyrTable->has(lyrname))
                pLyrTable->getAt(lyrname, pLyrTblRecord, AcDb::kForWrite, Adesk::kFalse);
                // pLyrTblRecord now points at the layer table record
                // which was opened for write
                pLyrTblRecord->setIsFrozen(Adesk::kFalse);
                //                pLyrTblRecord->setLinetypeObjectId(ltypeId);
        else
                // Note how we can change the open mode
                // of the layer table from AcDb::kForRead
                // to AcDb::kForWrite
                pLyrTable->upgradeOpen();
                pLyrTblRecord = new AcDbLayerTableRecord;
                pLyrTblRecord->setName(lyrname);
                pLyrTable->add(pLyrTblRecord);
        // Get the layer Table ObjectId
        recId = pLyrTblRecord->objectId();
        pLyrTblRecord->close();
        pLyrTable->close();
发表于 2005-12-24 19:12:06 | 显示全部楼层
非常不错!
GMT+8, 2026-11-5 22:53 , Processed in 0.461253 second(s), 38 queries , Gzip On.
