查看: 1451|回复: 2
[下载]:美国钢结构协会AISC发布2005版钢结构(及抗震)设计规范
发表于 2005-12-26 09:41:20 | 显示全部楼层 |阅读模式
[下载]美国钢结构协会AISC发布2005版钢结构设计规范
(意外惊喜,终于找到电子版的ASD了)
2005版建筑钢结构抗震规范的介绍为:
New 2005 AISC Seismic Provisions Now Available For Free Download
December 08, 2005 From American Institute of Steel Construction, Inc.
The new AISC seismic standard, Seismic Provisions for Structural Steel Buildings (ANSI/AISC 341-05) including Supplement No. 1 (ANSI/AISC 341s1-05), is now available for as a free download on the AISC web site.
This specification includes updated seismic design provisions and two new systems, buckling-restrained braced frames and special plate shear walls. It also incorporates both the allowable stress design (ASD) and load and resistance factor design (LRFD) methods. For a more complete description of the new provisions, see the Preface to the Provisions. This new specification supersedes the 2002 Seismic Provisions for Structural Steel Buildings and all previous versions of this specification. The new specification has been approved by the AISC Committee on Specifications and is ANSI-accredited.
下载链接:http://www.aisc.org/Content/Cont ... SeismicProv_web.pdf
2005版的钢结构规范的特点是将ASD和LRFD方在了一起。详见介绍:
Specification for Structural Steel Buildings, March 9, 2005
(ANSI/AISC 360-05)
2005 Specification provides the generally applicable requirements for the design and construction of structural steel buildings and other structures. This ANSI-approved specification is the first edition to incorporate ­both allowable stress design and load and resistance factor design methods. The design provisions for single angles and hollow structural sections are also included. Dual-units format provides for both U.S. customary and S.I. units.
Basic Design Values -Based upon the 2005 AISC Specification, these two 5x8 cards distill out only the typically needed and used information. With these cards, one can perform simplified analysis and design all typical beams, columns, braces, tension members, and connections. These cards cover W-shapes, channels, hollow structural sections, pipe, bolts, welds and connected parts. Both ASD and LRFD are covered.
全文下载为:
2005_Specification (PDF File)
http://www.aisc.org/Content/Cont ... _FINAL_revision.pdf
Commentary_2005_Specification (PDF File)
Basic_Design_Values (PDF File)
http://www.aisc.org/Content/Cont ... c_Design_Values.pdf
Cross-Reference List - Cross references the new 2005 Specification table of contents to the corresponding sections, where applicable, of past specifications. Cross references are given to the five standards that the 2005 Specification replaces. (PDF File)
http://www.aisc.org/Content/Cont ... /CROSREFLISTWEB.pdf
Copyright Permission Letter - The Copyright Permission Letter can be used to have additional copies of the 2005 Specification and Commentary made at your local print shop – just fill in the date at the top. (PDF File)
http://www.aisc.org/Content/Cont ... o_on_letterhead.pdf
AISC还同时发布了被命名为 13版的《钢结构设计手册》也同样将ASD(允许应力法)LRFD(极限承载力)收集在了一起
发表于 2006-11-16 23:20:40 | 显示全部楼层
thank u for the  best ...........
发表于 2006-11-20 12:07:09 | 显示全部楼层
thanks!
but i can't download it
GMT+8, 2026-11-22 10:11 , Processed in 0.299749 second(s), 14 queries , Gzip On, File On.
