查看: 2240|回复: 18
[转贴]:最致命的10种动物[Top 10 Deadliest Animals]
发表于 2005-12-29 11:56:28 | 显示全部楼层 |阅读模式
Poison Dart Frog有毒标枪蛙
These pint sized frogs aren't for kissing. Their backs ooze a slimy neurotoxin that is meant to keep predators away. Each frog produces enough of the toxin to kill 10 humans.
这些一品脱大小的蛙类,你可不能吻它们。它们的背上会渗出粘液状的神经毒素,让猎食者敬而远之。每只蛙分泌的毒素可以杀死10个人
 楼主| 发表于 2005-12-29 11:58:36 | 显示全部楼层
Cape Buffalo南非黑色大水牛
When faced with a predator, cape buffalos charge head on. That's 1,500 pounds of beast topped off with two big, sharp horns. You're lucky if there's only one – the real danger comes when a herd of thousands stampedes in your direction.
狭路相逢猎食者,南非黑色大水牛勇猛冲锋,这种1500磅的野兽会用两只大的尖角掀翻猎物。碰到一只,还算你幸运。如果几千只一大群向你狂奔而来,那才危险啦。
 楼主| 发表于 2005-12-29 11:59:41 | 显示全部楼层
Polar Bear北极熊
Sure they might look cuddly at the zoo, but in the wild they eat elephant seals for breakfast. Get between one and its cub and it could easily rip off your head with one swipe of its giant paw.
在动物园里,它让人真想抱抱它,但在野外它们拿海象当早餐。路遇一只成年熊和一只幼熊,用巨爪一击,就能轻易地将你的头给打下来。
 楼主| 发表于 2005-12-29 12:01:00 | 显示全部楼层
Elephant大象
Not every elephant is as friendly as Dumbo. Elephants kill more than 500 people a year worldwide. African elephants generally weigh in around 16,000 pounds – all the better to stomp you with – not to mention their sharp tusks.
不是每只大象都十分友好,每年在世界范围有500被大象杀死。非洲象一般体重16000磅,让它踩上可不得了,更不必领受它们尖尖的象牙。
 楼主| 发表于 2005-12-29 12:02:01 | 显示全部楼层
Australian Saltwater Crocodile澳洲咸水鳄鱼
Don't mistake this croc for a log! It can lay still in the water, waiting for passers by. Then, in the blink of an eye, it'll lunge at prey, pulling it under water to drown and dismember.
不要错把鳄鱼当木头,它会一动不动地呆在水里,等待猎物经过。在一眨眼功夫,它猛扑向猎物,拖到水里淹死,再肢解。
 楼主| 发表于 2005-12-29 12:03:18 | 显示全部楼层
African Lion非洲狮
Giant fangs? Check. Lightning quick? That too. Razor sharp claws? You betcha. Hungry? You better hope not. These big cats are near perfect hunters.
巨大的獠牙,闪电般的快速,剃刀样的尖下颌骨,它们饿了,才会有威胁?你敢打赌?最好别这样想,这些大猫是近乎完美的捕猎高手。
 楼主| 发表于 2005-12-29 12:04:54 | 显示全部楼层 |阅读模式
Great White Shark大白鲨
Blood in the water can excite these sharks into a feeding frenzy, where they'll use all 3,000 of their teeth to bite anything that moves.
水中的血会刺激它们疯狂的扑食,3000多只牙齿能咬碎一切能移动的物体。
 楼主| 发表于 2005-12-29 12:06:25 | 显示全部楼层
Australian Box Jellyfish澳洲水母
Also known as the sea wasp, this salad-bowl sized jellyfish can have up to 60 tentacles each 15 feet long. Each tentacle has 5,000 stinging cells and enough toxin to kill 60 humans.
绰号海洋中的黄蜂,咸水碗状水母有60条15英尺长的触须,每条触须上有5000个毒刺细胞,足够杀死60个人。
 楼主| 发表于 2005-12-29 12:08:00 | 显示全部楼层
Asian Cobra亚洲眼镜蛇
While the Asian Cobra doesn't hold the title of most venomous snake, it does the most with what it has. Of the 50,000 deaths by snakebite a year, Asian Cobras are responsible for the largest chunk. 亚洲眼镜蛇不是最毒的蛇,但作恶最甚,在每年被蛇咬死的5万人中,亚洲眼镜蛇食罪魁祸首。
 楼主| 发表于 2005-12-29 12:10:13 | 显示全部楼层
Mosquito蚊子
Most skeeter bites just make you itch. But some mosquitoes carry and transfer malaria causing parasites. As a result, these little pests are responsible for the deaths of more than two million people a year. 大多数蚊子咬了你,会让你觉得痒痒。但一些蚊子携带疟原虫,传播疟疾。
这些小小的害虫让200多万人死亡。
发表于 2005-12-29 13:35:25 | 显示全部楼层
开眼了
发表于 2005-12-29 19:40:39 | 显示全部楼层
其实最危险的是人,尤其是一些好战分子
发表于 2005-12-30 16:09:06 | 显示全部楼层
同意楼上的观点
发表于 2005-12-30 16:38:00 | 显示全部楼层
这些动物最好别在野外碰到他们,要不然。。。。。。
发表于 2006-1-14 13:49:58 | 显示全部楼层 |阅读模式
这个蚊子比较恐怖,平时大家都不当一回事。
GMT+8, 2026-11-3 07:31 , Processed in 0.777779 second(s), 65 queries , Gzip On.
