查看: 681|回复: 0
[分享]:给VBA初学者提供一个简单例程
已领礼包: 70个
发表于 2003-4-30 10:57:20 | 显示全部楼层 |阅读模式
'  在屏幕上选择若干点,然后将其坐标保存到文件
'  演示了选择集的建立和选择集中图元的处理
Sub OutputPoint()
    Dim PointObj As AcadPoint '点对象
  Dim SsetObj As AcadSelectionSet '选择集对象
  Dim x As Double, y As Double, z As Double
    Dim i As Integer
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    Dim groupCode As Variant, dataCode As Variant
    Open ThisDrawing.Path & "\points.txt" For Output As #1
    ' 设置选择集只能选择点对象
  gpCode(0) = 0
    dataValue(0) = "Point"
    groupCode = gpCode
    dataCode = dataValue
    ' 建立选择集并将用户在屏幕上选择的点加入选择集
  Set SsetObj = ThisDrawing.SelectionSets.Add("PointSet")
    SsetObj.SelectOnScreen groupCode, dataCode
    MsgBox "你选择了" & SsetObj.Count & "个点,坐标存入文件:" & ThisDrawing.Path & "\points.txt"
    For i = 1 To SsetObj.Count
            Set PointObj = SsetObj.Item(i - 1)
            x = PointObj.Coordinates(0)
            y = PointObj.Coordinates(1)
            z = PointObj.Coordinates(2)
            Print #1, i; " "; Format(y, "0.000"); "  "; Format(x, "0.000"); "  "; Format(z, "0.000")
    Next i
    SsetObj.Delete '删除选择集
  Close #1
End Sub
附件中是dvb文件。
GMT+8, 2026-11-2 06:14 , Processed in 0.696775 second(s), 31 queries , Gzip On.
